Between Trucks...
Best way to cut my dash...
I know it's sacrilege, but I'm thinking about cutting my dash for a stereo install. What's the best tool to cut the dash with and how do you go about measuring where to cut?
Beat it to fit, Paint it to match... ![]() |
I have a radical idea!
Re: Best way to cut my dash...
T'not to!!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
Cultural Infidel
![]() Join Date: Jan 2007
Dremmel tool with a solid cutting disk. You will probably need several. I used the steel box the radio slides into as a template. Go slow and don't cut any bigger than needed. It's an easy mod to do.
posted via La-Z-Boy -Mark 1972 C-10 Fleetside 350/TH350 PS PB A/C Cab Sadly....Sold ![]() 1968 Short Fleet 350/TH400 PS PB Delivered by Fine69 ![]() ![]() It may be that your whole purpose in life is simply to serve as a warning to others. A man is not complete until he is married -- then he is finished. |
18 Till I Die
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... ![]() |
that's what I want to do there...
How to cut your dash: 1. One get a rope 2. Find a tree 3. figure out the rest... ![]() Just kidding.. it's your truck so go for it.. I would say a good jigsaw will get the job done, or sutoff wheel
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
sheet metal scissors, it worked for all the previous owners
69 chevy c10 350 3 speed manual wood bed build thread here r.i.p. ![]() 70 c10 auto 350 build here Last edited by berencam; 05-12-2008 at 02:03 AM. |
18 Till I Die
I think some just used an axe...
its all about the +6 inches
lets not bash him... he's already made up his mind.
You can use a hack saw blade holding it with vice grips if you don't have a whole lot of tools. A dremel weould be cool, but I personally always seem to shatter those disks and that could hurt a LOT considering the close proximity of your FACE when doing this. A cut off wheel used carefully would be great, place an old blanket or cardboard over your nice seat and carpet if aplicable. I STRONGLY recomend NOT getting the jigsaw out. I trace the INSIDE if the stereo cage to the dash, leaving the excess gat at the bottom (you'll see what I mean as soon as you hold it up to the dash) so it is hidden better. Go slow, and you can always go back and trim more if need be. |
If you use a dremel get the good cutoff wheels. I have used the ones Andy talks about, and they suck. Dremel now makes some nice larger cutoff wheels that come with a quick change shaft, they work very well. Cut it a tiny bit smaller than needed, and then use a grinding wheel on the dremel to take the burs off. If you do it right, that cage will barely slide in.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Between Trucks...
Thanks for the replies, picking up a dremel on Mon., ordered my stereo today. Looking forward to cutting her up...
Cultural Infidel
You already know this, but please use adequate eye protection. The disks can shatter and the metal filings can cause serious eye damage. Be careful, go slow, no worries.
Official Site Guitar Shredder
i have used a jig saw in a pinch....by far the easiest....but if you have a a;ready painted dash..you might stay away from that method.....if you dont...use plenty of tape over your cut lines and where the jig saw ends may come in contact with the dash....go slow with a good blade it will take no time....i also agree on a cut off wheel....but again if your dash is already painted ..the heat might get the paint to hot and do some damage....im totally against the dremel..most I have seen lack enough power to do the job correctly .and jump and bog down....but thats just my opinion .and as Andy pointed out almost MOST of the time those discs are junk.....there are several ways of doing this air saw .plasma....its just what ever you feel the most comfortable using....good luck.....
ynot |
#13 |
If you are using a Dremel, and your dash is painted, use bad6772's advice and put a couple layers of tape on the dash. Tape it right around where you want to cut so if you ever slip you have a little protection there. It won't help if you jamb the wheel into the tape but if you slip it may be just enough to save your paint.
