05-12-2008, 05:21 AM | #1 |
rear 52"in front need bushings
Im putting 52" leaf springs in front but i cannot find bushings the fit my rears and fill the gap the original bushings dont have the extra padding on the side like the regular front bushings so if you guys have put 52" in front what kind of bushings have you guys use tank you in advance
05-12-2008, 07:35 AM | #2 |
60-66 Nut
Re: rear 52"in front need bushings
I'm not aware of any bushings that you could use that will make up the difference. There are 2 ways to solve your problem 1) make your shackles with a 'dogleg' in them to compensate for the difference between a 2 1/2" spring and a 3" spring. 2) get some of these (down at the bottom of the page) heavy washers to weld to your shackles to make up the difference.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 05-12-2008 at 07:36 AM. |
05-12-2008, 07:15 PM | #3 |
http://coloradok5.com/52inchspringswap.shtml
He talks about getting a wider bushing about half way down. |
05-16-2008, 05:31 PM | #4 |
let me know what you figure out
05-16-2008, 05:47 PM | #5 |
IIRC you can use aftermarket lift spring bushing in those. They are the same width 2 1/2", and the ID is the same....Summit sells them, and think they make only 2 different styles, one for Superlift and then the rest.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
05-17-2008, 09:34 PM | #6 |
FORD is a 4 letter word.
I can tell you right now, the superlift bushings won't work. The Eye diameter is too small. I got fed up with searching and just got the spacers from DIY4X.
'71 406 GMC Short Box Fleetside - Daily Driver '79 350 Chevy K-5 Blazer - On-going Project (Mudder)www.wnyoffroad.com '58 LT1 Chevy Short Box Step Side - Next Project |
06-01-2008, 08:00 AM | #7 |
got tired of looking so i got the washers spacers diy4x sell
