Old 05-12-2008, 06:49 AM   #1
powerbench
powerbench's Avatar
lower control arm trimming
Does any one have a picture of how much they had to grind to fit 15 inch ralleys on. Going to do 2 and 1/2 spindle with 1 inch coil in front ,and 6 out back from ece. I just bought 6 1/2 for the front and 8's for the back. If i have to do any grinding , i'd like to do it now before i sand blast and paint the control arms. Also should i reinforce the inside if it needs clearancing? Thanks
powerbench is offline   Reply With Quote
Old 05-12-2008, 08:01 AM   #2
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
Re: lower control arm trimming
What year truck?
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 05-12-2008, 08:05 AM   #3
powerbench
powerbench's Avatar
70 gmc...with 72 chevy suspension. 1/2 ton
Old 05-12-2008, 08:16 AM   #4
dieselarmy13
You shouldn't have to do any trimming at all, especially if you are running 6.5's on the front. The only time you have to trim them is with some aftermarket wheels.
Old 05-12-2008, 07:02 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
I would trim them anyway. You never know when you might have to bolt on a different wheel. (as in spare tire?) Anything with more than 3 1/2 inches of backspacing will require trimming with a 3" drop spindle. I'm not sure about the 2 1/2" spindles. I have done it to all of them regardless of the year. Also remove the metal bumpstop bracket. I like to trim off ONLY the part that holds the "factory" rubber bumpstop,... and leave the steering stop. If you had a picture of the lower a-arm,... I could show you where to trim it.
Keith
Convert to disc brakes.
Old 05-12-2008, 07:30 PM   #6
powerbench
powerbench's Avatar
cool , i'll try and get some pics after i go see mom..thanks
Old 05-12-2008, 08:15 PM   #7
hotrodhomi
hotrodhomi's Avatar
I had to grind my spindle a little but not my arms, I swapped them out for '73+ though.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 05-13-2008, 04:54 AM   #8
70c10
67-72 Addict!
70c10's Avatar
I run 3.5" B.S. on a 8" rim with 275/60/15 tires. My 2.5" drop spindles needed 1/8" at most trimmed to clear my wheel weights on the backside of the rims. If my rims would have been 7" I would have been fine.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 05-13-2008, 08:03 AM   #9
powerbench
powerbench's Avatar
ok shoot, didn't get home from mom's until now but went out and mesured the back space on the truck rally's looks like 4 and a1/4...i'll have to get some pics of the rims here when i finsh up making a late dinner
Old 05-14-2008, 06:48 AM   #10
powerbench
powerbench's Avatar
Name:  control arm small.JPG
Name:  control arm small 2.JPG
Name:  wheels small.JPG
Name:  wheels small 2.JPG
Size:  49.2 KB Well i hope these pics will do as far as cutting the bump stop and where to slim down the lower arm ..if i need
Old 05-14-2008, 02:48 PM   #11
lolife99
lolife99's Avatar
Here's a bad picture of the trimmed area.
Keith
Old 05-14-2008, 04:55 PM   #12
lolife99
lolife99's Avatar
Here's a top view,...
Keith
Old 05-14-2008, 07:58 PM   #13
SCOTI
SCOTI's Avatar
Just so you know.... the 4.25" BS measurement sounds like a truck wheel. In the pics you posted, there are 2 truck wheels & 2 van wheels. The van wheels should fit up front w/2.5 drop spindles & no cutting.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-15-2008, 02:59 AM   #14
powerbench
powerbench's Avatar
Thanks for all the help guys. Ya thats what i had heard Scoti , but when i check both rear and front rims ,they have the same back spacing . The rears have ,(Iguess) the extra 3 and 3/4of depth to make 8 inch , and the fronts have the 2 inches to make up 6 and a 1/2 ? sound right? Kinda going for that hot rod ,drag race , tough truck look Again thanks .
Old 05-14-2008, 06:55 PM   #15
hotrodhomi
hotrodhomi's Avatar
I cut mine off with a sawsall and then used a grinder to make it flush
'66 impala ht
