Old 05-12-2008, 04:59 PM   #1
Green Machine
Green Machine's Avatar
Pic(s) Wanted - Dana 60 under C20 - Coil Spring
Trying to install a Dana 60 coil 8 lug rear under our 1971 C20, originally had the old style Eaton. Having a few issues, original track bar is to long and brake hose is too short. A few pics might help me figure this out, like where the brake hose connects to the rear and comes out of the frame. Might be some differences between the suburban setup and the truck. Any pics would be helpful. I might ask for a measurement of two also if you don't mind.
Thanks.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 05-12-2008, 05:09 PM   #2
haysonj
haysonj's Avatar
Re: Pic(s) Wanted - Dana 60 under C20 - Coil Spring
I don't have coil springs but when I put the 14 bolt under mine I had to have a new rubber hose made as mine was too short also.
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 05-12-2008, 08:51 PM   #3
circuit_doc
1968 Custom Camper
circuit_doc's Avatar
Hope these help. When I purchased the rubber brake hose it was specified that fit a DANA 60 and it was longer then one for other rears. It's going over 100 degrees here today so there are some shadows.
circuit_doc is offline   Reply With Quote
Old 05-13-2008, 05:31 PM   #4
Green Machine
Thanks for the pics- leaf spring brake hose is mounted different on the axle and the frame - anyone have some coil spring dana 60 pics ? Thanks.
