Old 05-12-2008, 05:27 PM   #1
thirdstreettito
Resident of Here
thirdstreettito's Avatar
6.2L Diesel
Anyone here have one? I am getting one and I have found some performance parts to help it up to atleast 750ftlbs. Post yours if you have one! Or post anything you know about them!
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 05-12-2008, 05:59 PM   #2
HanSoloWS6
HanSoloWS6's Avatar
Re: 6.2L Diesel
I have one and have been looking for some things to give it a little more go. But all I have found lately is a set of headers and a turbo kit from Banks. But I need to get it running again before I do anything lol.
"Locomotion" - 1982 C10 LWB
6.2 to 6.5 HUMVEE non turbo swap complete
Pop's Garage Photography - Dayton, Ohio
My Truck Build Page
HanSoloWS6 is offline   Reply With Quote
Old 05-12-2008, 06:48 PM   #3
Russell
Professional Grade
Russell's Avatar
Re: 6.2L Diesel
Wanna pass on some details on how you can make that much torque reliably?
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 05-12-2008, 11:14 PM   #4
Ivan D.
glamoros piece o' lowlife
Ivan D.'s Avatar
Re: 6.2L Diesel
Yeah man, that's more than double the torque the engine was rated at stock, you gotta start replacing rotating assembly parts if you're gonna run that much, and there's still the strength limitation of the block itself - IIRC there was an issue with them being prone to cracking in certain areas, and there are new castings (by World?) now that have much thicker webbing for avoiding just that... So yeah, what mods exactly you gonna do to this engine to achieve that high power level?
The more I drink, the more I drink, the more I drink...
diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express
Ivan D. is offline   Reply With Quote
Old 05-12-2008, 11:27 PM   #5
thirdstreettito
Resident of Here
Re: 6.2L Diesel
I am of course gonna get the Sidewinder, a custom exhaust system, 3:42 or 3:73 rear end, bore it out a little, methanol injection, and a few other things.
~Bradley~
Miss having a truck
Old 05-12-2008, 11:41 PM   #6
Ivan D.
Ivan D.'s Avatar
Re: 6.2L Diesel
Riiight, and that's gonna get you 750lb-ft? No lower compression pistons, stronger rods, none of that? What about those weak spots in the webbing I mentioned, have you done any research on those?
Old 05-12-2008, 11:59 PM   #7
thirdstreettito
Resident of Here
Re: 6.2L Diesel
I am in the middle of researching a lot of stuff for it.
~Bradley~
Miss having a truck
Old 05-13-2008, 02:07 AM   #8
Pyrotechnic
Pyrotechnic's Avatar
Re: 6.2L Diesel
You would actually be dollars ahead doing a Duramax/Allison swap and starting from there. There's a lot more power potential in stock form there than in a 6.2 or 6.5.
Pyrotechnic is offline   Reply With Quote
Old 05-13-2008, 06:18 AM   #9
Ivan D.
Ivan D.'s Avatar
Re: 6.2L Diesel
Good, good - I ain't nagging on you just cause I'm a jack, tis just I've seen way too many projects begin all optimistic and end up poor, or not get finished at all, cause the person never planned it right.
Old 05-13-2008, 07:46 AM   #10
Russell
Professional Grade
Russell's Avatar
Re: 6.2L Diesel
Make a stop at www.thedieselpage.com and www.thedieselplace.com
Both websites have forums full of a great deal of information. I personally feel that 750 ft lbs is a very optimistic number. I'd suggest that a very well built 6.5L would make at most 500 ft lbs reliably.
I am personally aiming for approx 400, and thats with a lot of goodies put into the engine!
Old 05-13-2008, 04:14 PM   #11
thirdstreettito
Resident of Here
Re: 6.2L Diesel
I have been a member of The Diesel Place for a couple months. I cant afford The Diesel Page, I emailed them a question and they told me to buy their book, so I called them a bunch of greedy bastards because they couldn't even tell me one thing.
~Bradley~
Miss having a truck
Old 05-13-2008, 08:03 PM   #12
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
Re: 6.2L Diesel
The only thing you are going to build there is a timebomb. The diesel page is worth the price. Trust me. You will spend more on broken parts than the fees. These guys have already broken everything for you.
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 06-19-2008, 08:24 PM   #13
superflydude
superflydude's Avatar
Re: 6.2L Diesel
How good are the 24v 6.2l diesels that the military used? Do they come with a lot of problems or is it a good engine?
"Who needs rocker boxes..."
superflydude is offline   Reply With Quote
Old 06-19-2008, 09:21 PM   #14
79GMC_OLDS
79GMC_OLDS's Avatar
Re: 6.2L Diesel
if you want 750ftlbs reliably and relatievly cheap and still get good fuel mileage..12 valve cummins is your answer. You also have to consider a drivetrain that can handle that kind of power.. 750 ftlbs wrecks stuff
79 GMC Sierra 5.9 cummins, nv4500
79GMC_OLDS is offline   Reply With Quote
Old 06-19-2008, 09:28 PM   #15
semperfidoordie
Fix It Till It's Broke
semperfidoordie's Avatar
Re: 6.2L Diesel
does anyone know how direct the swap is? I'm not looking for anything crazy in hp or ft lb numbers just want a solid diesel 4x4...this is a project that will happen down the road of course gotta find a gutless 4x4 for cheap and throw a diesel in it just to play around and go muddin in
Tony
Black Beauty: 85 C-10 SOLD!
Great White: 69 LWB Custom Camper/20 SOLD!
Blue Dragon: 72 K-10 SOLD!
The Tank 77 K-10 KIA
panhandler62: Just don't search for "trannys" no matter how hard yours shifts -- you just won't get what you are looking for.
I Made The Official So Cal Board Meet
semperfidoordie is offline   Reply With Quote
Old 06-20-2008, 01:42 PM   #16
thirdstreettito
Resident of Here
Re: 6.2L Diesel
There is a guy in the "Projects and Builds" section with a 12valve in a 72'. Ask him he would definitely know.
~Bradley~
Miss having a truck
Old 06-20-2008, 04:24 PM   #17
semperfidoordie
Re: 6.2L Diesel
thanks man
Tony
Old 06-20-2008, 04:57 PM   #18
BIGCHEVYMAN
BIGCHEVYMAN's Avatar
Re: 6.2L Diesel
i have a 6.2 wuth a banks turbo and it is ok,I am kinda getting tired of the little quirks of these engines. I'm looking at selling this truck and getting something with a gas motor. IF you get that kinda of torque out of one of these motors it will not last long. the block will crack or the crank will break.
BIGCHEVYMAN is offline   Reply With Quote
