Old 05-12-2008, 09:27 PM   #1
Sinister
Between Trucks...
Sinister's Avatar
Question Speakers in doors
PO of my truck cut the doors for speakers, so thats where mine are going to go.
He cut them for not one, but 2 sets of speakers. How are you guys running the wiring for speakers in the doors? Pics if you got em.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 05-13-2008, 12:26 AM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Speakers in doors
I ran my wires through the body just infront of the doors (drilled a hole in the metal and fed the wire up to just behind the dash. The wire went through the front of the door (another hole drilled) and then I put rubber grommets in around the wire.
piecesparts is offline   Reply With Quote
Old 05-13-2008, 12:32 AM   #3
Sinister
Between Trucks...
Sinister's Avatar
Thanks, I'm gonna go take a peak at my truck and see what's up. I already have the holes drilled in the front of the doors, just gotta figure out the rest...
Beat it to fit,
Old 05-13-2008, 07:59 PM   #4
Sinister
Between Trucks...
Sinister's Avatar
Originally Posted by piecesparts View Post
I ran my wires through the body just in front of the doors (drilled a hole in the metal and fed the wire up to just behind the dash. The wire went through the front of the door (another hole drilled) and then I put rubber grommets in around the wire.
I'm kind of having a hard time getting my head around this. The part about running the wires through the body, I can't figure how the wires get to the dash. It looks like the wires would be trapped behind the kick panel vent area.
Beat it to fit,
Old 05-13-2008, 08:14 PM   #5
SactoJim
SactoJim's Avatar
I had to drill a small hole in the kick panel and fish wires through. I have carpet covered kick panels, so the hole is covered. If you don't have covers you could drill low enough to go under carpet.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 05-13-2008, 09:08 PM   #6
lks dcvn
lks dcvn's Avatar
Also be sure to stagger the exit (from the kick panel) and the entrance (to the door) - this will allow for some slack when opening/closing the door and reduce the possibility of rubbing through the wiring...
If you want an example the PO did this on my project truck and I have the front fenders off so I can take a picture of what I am talking about...
PM if you need a shot or two.
lks dcvn is offline   Reply With Quote
Old 05-13-2008, 09:12 PM   #7
jimmydean
jimmydean's Avatar
Use grommets on the holes, or some silicone will also work so the wire isn't sitting on the cut metal of the door.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 05-13-2008, 09:25 PM   #8
VA72C10
VA72C10
VA72C10's Avatar
If you could post them here or pm them to me also, i'd appreciate it as well!
Thanks!
VA72C10 is offline   Reply With Quote
Old 05-13-2008, 09:28 PM   #9
72BlckButy
Tot Roddin'
72BlckButy's Avatar
According to the PO... "what are rubber grommets?"
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 05-13-2008, 09:50 PM   #10
lks dcvn
lks dcvn's Avatar
snagged this pic from Rokcrln's Low-Buck build...
Not a great picture - but gives you the idea...
I will try to get better pix when I get home from work tonight...and I will post them up in here...
Old 05-13-2008, 10:12 PM   #11
Sinister
Between Trucks...
Sinister's Avatar
I went back out to my truck to take a look, and still can not figure this out. It seems like there is a double wall in the kick panel area, I have no idea how you could fish the wires through. My brain must be on vacation today.
Beat it to fit,
Old 05-13-2008, 10:28 PM   #12
jayharrell
Gettin By on Gettin By
jayharrell's Avatar
I've seen some guys that have the touch knobs, hard to explain. Contacts ends, little round nubbs that touch when you shut the door. Not sure how well they work.
I'll try to gather up a pick, i'm sure someone has an example.
69 CST10 LWB 455 Buick
00 S10 2.2 Vin5
76 GL1000 Naked 1bl VW carb
"Adios to all the concrete; Gonna get me some dirt road back streets"
jayharrell is offline   Reply With Quote
Old 05-13-2008, 10:39 PM   #13
Sinister
Between Trucks...
Sinister's Avatar
This pic helped a bunch. I didn't see where the wires were coming through at first. Thanks dude.
Beat it to fit,
Old 05-13-2008, 10:40 PM   #14
El Jay
Gone to greener pastures
On my Chevy, the PO ran the wires into the vent. Then he brought them out to the left and forward of where these wires exit. Kind of at the "back" of the front fender, would be the best way to describe it.
On my GMC, the installer ran the speaker wires under the edge of the carpet to the weatherstripping. Then up inside the weatherstripping for about 3" and then around the door jamb & into the front of the door.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 05-13-2008, 10:42 PM   #15
SactoJim
SactoJim's Avatar
Drill holes......use grommets. Then with some patience and some rigid wire (clothes hanger) bent as needed and negotiated through holes, you can pull your speaker wires through. Not too tough at all.
- supercharged 383
- 4 wheel discs
My Build Thread
Old 05-14-2008, 05:10 AM   #16
lks dcvn
lks dcvn's Avatar
Got the pix when I got home and didn't get a chance to post them until now...
The PO of my project fished them through the lower cowl area - totally hidden when fenders are on and even less friction from wires...
1st pic is straight down the psgr side with the door open
2nd pic is standing in the doorway looking toward the front of the cab...
If you need more - let me know.
Hope that helps.
Old 05-14-2008, 05:27 AM   #17
tcb-1
Nothing to see here.....
tcb-1's Avatar
Sin,
Also use a heavy gauge heat shrink between the door and the body. That will help cut down on cut wires when the door is open.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 05-14-2008, 05:55 AM   #18
harrdawg54
harrdawg54's Avatar
If you want something that looks nice and is inexpensive, give this link a try.
http://www.a1electric.com/Merchant2/...t_Code=Boot-Sm
1969 Chevy K20 Custom Camper
350, 4sp, 33's
High on plans, Low on funds
harrdawg54 is offline   Reply With Quote
Old 05-14-2008, 06:20 AM   #19
Pl4yboy
Freeeeee Mason...
Pl4yboy's Avatar
I ran mine in simple black wire looms just to be safe.
Daily Driver
-2007 Chevy
-Dark Blue Metallic
-Regular Cab
-4.8 V8
-4x4
Ongoing, Never Ending, PITA, Love of my Life
-69 Chevy C/10, Camper Special
-350/TH400
-Loudest System on the Board
Pl4yboy is offline   Reply With Quote
