05-12-2008, 10:32 PM | #1 |
go cyclones
Heater Box clean up ideas
I've got my heater box and AC box off right now. What are some of the things you guys have done to clean this up? Also can I find the puddy that goes on the condensor line?
Thanks |
05-13-2008, 02:52 AM | #2 |
Re: Heater Box clean up ideas
I use alternate washing of the box with mineral spirits and Simple Green.
Unless they have been in the sun they will clean up nicely. If yours has been bleached by the sun, clean it well and clear coat it. The black stuff is available from a good AC parts supplier. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC Last edited by JimKshortstep4x4; 05-13-2008 at 02:53 AM. Reason: Spelling |
05-13-2008, 03:04 AM | #3 |
The putty you are looking for is discontinued from GM now, the only places that I have been able to get the correct stuff is from Ricks 1st generation Camaro Parts in Georgia which comes in a NPD package- National Parts Depot. The NPD is cheaper than the same stuff from Ricks but Ricks are nice folks to deal with. The roll that you get is a little smaller than what came originally on your truck but will work. Use warm saopy water and the bath tub to clean the housing then locate cast blast or cast coat - NAPA details line of spray paint - it will put your color close to original -this is what mine looks like after this process.
05-13-2008, 03:43 AM | #4 |
what was the orig color on the heater box ? from the factory
05-13-2008, 04:45 AM | #5 |
black
1967 c-10 longbox project, check it out in projects 1969 c-10 parts pickup, twisted frame Daily driver- 1970 Olds delta 88, 2dr., 455, gotta love the big block |
05-13-2008, 05:03 AM | #6 |
Tot Roddin'
71 super... that is clean!!!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
05-13-2008, 06:22 AM | #7 |
They were originally a raw fiberglass. They grey with age to a lighter version. The cast color is the closest that I have came across that looks as original. The box on my 71 (second pic.) is the first one I did, that pic. is recent- last 3 months- truck has been finished since 2000, the first box is the box that is going back on my 72 4x4. I think the second one actually turned out better than the first- it looks better now as I have since installed the Harrison sticker on the outside of the box
05-13-2008, 12:36 PM | #8 |
Harold,
Great job on your AC box! Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
05-13-2008, 08:41 PM | #9 |
"Trucks with Class"
I think our best source for OEM original replacement parts for factory AC is: Old Air, out of TX. They have some nice systems & parts for our trucks.
05-13-2008, 09:06 PM | #10 |
The material on the refrigerant line is termed "cork-tape". It is an insulating material used in HVAC. It should be available in roll form at an HVAC supply house.
05-13-2008, 09:52 PM | #11 |
Dan that is good info to have thank you! Thanks for the nice comments Jim and BlkB.
05-14-2008, 02:44 PM | #12 |
go cyclones
Thanks for the info, guess I will just clean up the box and paint it. They were a bit faded and have a bunch of overspray on them. 71 Super, I will try and come close and match your skills.
05-14-2008, 06:01 PM | #13 |
Sierra Grande Club
I used Gibbs oil on mine and its perfect. I think paint takes away from the “original” look- JMO. Pictures here on the bottom of this thread. And to answer your question…No it doesn’t collect dust. It’s sitting out in the garage now, and my powder coated parts are collecting more dust than my heater box! This stuff is awesome.
Enjoy. s/t http://67-72chevytrucks.com/vboard/s...ighlight=gibbs
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. Last edited by Sport/Truck; 05-14-2008 at 06:02 PM. |
05-14-2008, 08:07 PM | #14 |
3m Strip Caulk is what wraps the condenser line! The same as the stuff used to seal off the fire wall.
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
06-04-2008, 10:41 PM | #15 |
go cyclones
Hey Super 71, it didn't turn out quite as nice as yours but I am pleased with it.
06-04-2008, 11:20 PM | #16 |
Looks good to me! Nice job!! Do I spy a later model compressor on your engine? What are you going to do for lines?
06-05-2008, 12:06 AM | #17 |
Nice work to both of you!
Jef
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
06-05-2008, 08:05 AM | #18 |
go cyclones
I'm going to have to have some custom lines made up. I would try looking for a coupling but going from standard to metric I think it will be easier just to have someone compress the correct fitting on the line.
06-05-2008, 08:39 AM | #19 |
Here is how I cleaned mine up. I got Vintage air under the dash.
