Old 05-12-2008, 11:12 PM   #1
crm318
Alright Alright Alright
crm318's Avatar
factory oil pressure fitting help
i had to remove my factory oil pressure fitting from the back of my block and it was if someone put it on with an impact wrench. i had to cut the line at the fitting and i destroyed the fitting trying to get it off. im now trying to find the factory fitting at autoparts stores but i have had abosolutly no luck. what should i do?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 05-12-2008, 11:57 PM   #2
Sammy
Re: factory oil pressure fitting help
Removing em with anything but a six point is a must even used pr of vice grips also. Best to get one from a member a original item or e-bay. I had no luck w/replacement @ the parts store either.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 05-13-2008, 12:08 AM   #3
HoupPhotography
Is it the copper or plastic line? If it's plastic it will be an easier fix with a ball nut (I think that's what it's called, someone will know the proper name if it's wrong), if it's copper you need a flange tool. The nut itself I believe is 7\16, I went to home depot to find one instead of the local auto parts store. You can find both types of nuts I'm talking about there in the plumbing section, possibly a flange tool too.
EDIT: I guess I should of asked, Do you needed the actual fittig that goes into the intake or the nut with the line attached that bolts to the fitting iself? If you have the actual fitting off (the piece that goes into the intake), take it with you to home depot, you can get that there also.
R.I.P. Scott Kalitta
HoupPhotography is offline   Reply With Quote
Old 05-13-2008, 04:53 AM   #4
crm318
crm318's Avatar
i could have specified better. its the copper line and i need the nut that attaches to the fitting (the upper part with the line in it). it looked like the copper line is pressed into it.
1972 Cheyenne
Old 05-13-2008, 05:04 AM   #5
LockDoc
The Older Generation
LockDoc's Avatar
You will need a 1/8" compression nut & sleeve. Your local hardware store, or auto parts store, or plumbing shop should have it....
It would be the first two parts on this page.
http://www.plumbingworld.com/compres..._fittings.html
LockDoc
Leon
Old 05-13-2008, 05:09 AM   #6
70c10
67-72 Addict!
70c10's Avatar
Is this the part you need?. I think this is the line that goes from the gauge and connects to the other line at the back of the intake. LockDoc is correct!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 05-13-2008, 05:10 AM   #7
LockDoc
LockDoc's Avatar
Well, after reading your post again scroll on down to the "Compression x Mips Adapters" section on that same page. If you need the part that screws into the block it will be the "1/8" Comp x 1/8" Mips" fitting.
LockDoc
Leon
Old 05-13-2008, 05:13 AM   #8
HoupPhotography
LockDoc
That's it, a compression nut! Sorry for the bad info man!
Old 05-13-2008, 01:09 PM   #9
Blazer1970
Blazer1970's Avatar
Yup, those are just basic plumbing parts.
Blazer1970 is offline   Reply With Quote
