Old 05-12-2008, 11:18 PM   #1
crm318
Alright Alright Alright
crm318's Avatar
starter wire help
im in the process of putting my engine back in my truck and i noticed that one of my starter wires had burned up and broke off. if you looking at the soliniod from the front, there is the battery cable connection and two little wires on either sides. im missing the one that is on the left side furthest from the block. i still have the purple wire that goes on the right hand connection. where does the missing wire go to?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 05-12-2008, 11:25 PM   #2
john
member #16
john's Avatar
Re: starter wire help
If you have a points dist. it will go to the + on the coil If your upgraded to electronic it is not used.
john is offline   Reply With Quote
