11-05-2002, 01:13 AM | #1 |
What makes a good K5 street driver?
I have a K5 that is pretty much stock. I think only changes are rallies with 31" tires. It has some body roll and bounce (although it has new stock shocks) that I would like to address. Nothing super bad, but I do have to fight it on rough streets. It also has original springs, front and rear. Anyone have any recommendations on how to reduce body roll?
Thanks in advance. ...Dan |
11-05-2002, 01:22 AM | #2 |
My other Love
dont go around the corners so fast? it is a 4x4. Maybe get a rear sway bar and poly endlinks and bushings for the front sway bar
Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
11-05-2002, 01:39 AM | #3 |
Member since 2000
http://67-72chevytrucks.com/vboard/s...threadid=25623
that link should help some. i would change out the shocks to some ranchos 5-speeds. |
11-05-2002, 08:41 AM | #4 |
The first mod would be to add a front sway bar. Starting in 1973, all 4X4s got them. The later model parts can be adapted to work, or there are aftermarket kits available (not sure where).
Tim |
11-05-2002, 09:50 AM | #5 |
You probably don't want to hear this but---those 33's are not helping your ride or handleing. Low wide tires would give you much better handeling and maybe a new look that would grow on you~~!
11-05-2002, 11:22 AM | #6 |
Thanks for the response.
I will try slowing down and adding the sway bars now. Will address tires and shocks next. ...Dan |
