doors and seals
well I succesfuly got the doors hung.. ( finished the drivers side today). I temporarily installed ( tacked up with masking tape) a door seal that I purchased from Brothers and the fit seems good, it just requires a push to close entirely the last 3/16 of an inch or so. So the question is...... should the door seals be installed before the foor mat I ssume? I am using the rubber mat with felt backing.
Thanks again
69 K-20 cloned to a 67 with front clip and some other stuff. 383 .040 over Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears: ![]() |
Re: doors and seals
Yes: and no, yes if your careful with the mat install. no if your not (mat draging in over the unprotected seal may rip or tear the door seal) 463
Trueman |
