05-13-2008, 05:55 AM | #1 |
8" Brake booster... Will it work????
Im considering installing an 8" dual diaphragm brake booster on the frame rail. I dont have enough room to fit a larger booster because of ground clearance. I was wondering if anyone has had any experience with, or or has installed one on their truck. Does it provide enough brake pressure, or do i need to go with a 9 or 11" booster? I spoke with someone from Baer, and they said that if the pedal has a ratio of 6:1 that it should provide the same pressure as an 11" booster. So i dont know what to do... but thats the info I have. If you guys can help, let me know. Thanks!
05-14-2008, 07:14 AM | #2 |
Seņor Member
Re: 8" Brake booster... Will it work????
I'm using a 7" dual diaphragm booster and it works fine.
