Old 05-13-2008, 06:51 AM   #1
Pont406
I installed a mini tach.
I was looking for something else but I found a mini tach instead in the garage. I hope it doesn't look like too much rice.
Pont406 is offline   Reply With Quote
Old 05-13-2008, 06:56 AM   #2
HoupPhotography
Re: I installed a mini tach.
I have a very simular tach, in the exact location... I hope it doesn't look rice, my vote is no
R.I.P. Scott Kalitta
HoupPhotography is offline   Reply With Quote
Old 05-13-2008, 06:59 AM   #3
1tigers
Is your tac not working in your dash
1tigers is offline   Reply With Quote
Old 05-13-2008, 07:00 AM   #4
VA72C10
VA72C10
VA72C10's Avatar
My question would be is why not use the factory tach? It looks like there is one in the picture?
VA72C10 is offline   Reply With Quote
Old 05-13-2008, 07:01 AM   #5
72BlckButy
Tot Roddin'
72BlckButy's Avatar
If it's like mine... it would only run to 2,500 rpm and then freeze. I added a sunpro tach until I have the time to pull the dash and figure out what's wrong with the guage.
Now as far as the painted horn button... a little rice action (painted interiors) going on. Just kidding!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 05-13-2008, 07:05 AM   #6
Pont406
Factory tach works but it's off by 1400 rpm or so. Painted horn button was PO work.
Old 05-13-2008, 08:58 AM   #7
N2GMTrux
N2GMTrux's Avatar
What size engine is in the truck and do you have a 50 or 60 grand factory tach.
N2GMTrux is offline   Reply With Quote
Old 05-13-2008, 01:00 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the factory truck ones only went to 5 grand.
I wouldn't exactly call that a Mini tach either... a mini would almost fit in the ACC guage holes on the bottom of your inst panel.
Old 05-13-2008, 02:28 PM   #9
Ace in the hole
I opted to go with one installed in the gauge hole-
I had to cut out one line of the printed circuit but it is a ground line and I was able to just put a screw in the other side to re-ground it, hopefully you can see it in the pic.
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 05-13-2008, 02:43 PM   #10
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
Question Re: I installed a mini tach.
What Size tach is that your useing or Part# it looks like it fits perfect Im in the market for one now just not sure what to Buy size wise? And What do you guys mean 50 or 60 Grand.. Is that the highest RPM the tach goes to Do I need something higher than 6Grand.? For a 454BBC
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 05-13-2008, 03:10 PM   #11
haysonj
haysonj's Avatar
Unless your racing it that 454 will never see 5000 454 in boats redline at around 4900
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 05-13-2008, 04:46 PM   #12
ap2002
how hard is it to install one those gauges? i really need one...
1971 C-10 SWB - LS swap w/4L60e, 20x8.5front 20x12rear,
1968 C-10 SWB - 454 BB TH350 -Gone!
ap2002 is offline   Reply With Quote
Old 05-13-2008, 05:42 PM   #13
Ace in the hole
Did not intend to hijack this thread but I figured we are talking tach's so it would be ok. The install of mine was really simple. It's a vdo "vision series" gauge, number 333155. It is programable for 4, 6 or 8 cylinders.
I took a hole saw and cut the plastic lens out, cut the front tin plate and the back tin plate. Then assembled it all and cut the printed circuit board where I needed to. The gauge mounts so simple right to the front bezel with a plastic screw on ring. As for wiring it, you need power, ground and the signal connections along with the dash light connections. I am going to tap off the ground screw for all the grounds, off the temperature gauge feed screw for power (need to figure out which side) and run a lead from my hei dist. for the signal. You can also use a signal from a alternator lead. The lights I will just tap into the wire for the dash lights on the harness.
Old 05-13-2008, 07:31 PM   #14
chrislehr
Engine n00b
chrislehr's Avatar
In for this answer as well - where did you find that tach?
chrislehr is offline   Reply With Quote
Old 05-13-2008, 08:16 PM   #15
Ace in the hole
It's a vdo gauge and there are lots of places that sell vdo. I got it at summit.
here- http://store.summitracing.com/partde...5&autoview=sku
Old 05-13-2008, 08:24 PM   #16
HoupPhotography
Originally Posted by 72BlckButy View Post
. I added a sunpro tach .......!
Isn't that one of those 10' tachs with a spot light shift light.... that are in 99.998% of ricers? j\k
Old 05-13-2008, 09:41 PM   #17
rambler
MOVE OVER
rambler's Avatar
previously werent guys putting in older camero tachs in the gas gauge location and relocating the gas guage? I really dont need a gas guage anyway,,, its always on Empty.....
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 05-13-2008, 09:45 PM   #18
berencam
berencam's Avatar
just say no
69 chevy c10 350 3 speed manual wood bed build thread here r.i.p.
70 c10 auto 350 build here
berencam is offline   Reply With Quote
