Old 05-13-2008, 01:48 PM   #1
mike nutt
69fatmotor
mike nutt's Avatar
tank switcher valve question.
on an '85 when swapping in a late model efi engine with the 55psi plus fuel system what switching valve would you use if keeping factory duel tanks . any help would be greatly appreciated.
mike nutt is offline   Reply With Quote
Old 05-13-2008, 03:02 PM   #2
slug
slug's Avatar
Re: tank switcher valve question.
i would think that the stock valve would work. are you going to put in-tank fuel pumps in?? or are you going to use a external pump??
there is nothing better than cutting metal with fire.......except cutting metal with electricity!!!
slug is offline   Reply With Quote
Old 05-13-2008, 03:09 PM   #3
mike nutt
69fatmotor
mike nutt's Avatar
i will be using the '87 sending unit with the later intank fuel pump , i just wasn't sure if the valve for the '87 tpi efi would hold the pressure of the later model efi.
Old 05-13-2008, 04:20 PM   #4
slug
slug's Avatar
you could call a parts house and see if the part number for the valves is the same for a 85 & 87. make sure what ever valve you use is the 6 port one.
