Old 05-13-2008, 02:05 PM   #1
67Mach1
67Mach1's Avatar
Did our trucks have Choke Cable as option?
One of my parts trucks has a Choke Cable under the dash just to the left of the steering wheel.
Is this something that would have been dealer/factory installed or an aftermarket item? The knob has a white C on a black Knob.
I took a photo but need to get them downloaded.
Just looking for an expert opinion....
Thanks,
Soon to be selling all but one, or two... Depends on what the Boss has to say.......
67 GMC Shortbed 454 Project
more junk and most of it
is for sale
67Mach1 is offline   Reply With Quote
Old 05-13-2008, 02:29 PM   #2
Re: Did our trucks have Choke Cable as option?
67 and 68 had it standard in the gauge cluster.
If it is where you said, it was aftermarket, which was VERY common for these trucks as the automatic chocks of those days did leave something to be desired if they were not in top notch form.
Old 05-13-2008, 04:21 PM   #3
boundstaffpress
Jamie Hyneman is my twin
boundstaffpress's Avatar
My dad's 71 had the choke mounted where you said, and had a white C on the handle. It also had a manual choke set-up for a quadrajet. I always assumed it was dealer add on.
Justin
SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD
Color Wiring Diagrams Now in High Resolution
V8 and Cab and Cab and Chassis
boundstaffpress is offline   Reply With Quote
Old 05-13-2008, 04:35 PM   #4
69long"n"low
69long"n"low's Avatar
I got one on the right side of e steering wheel between the wheel and the ignition
69long"n"low is offline   Reply With Quote
Old 06-16-2008, 08:19 PM   #5
msgross
msgross's Avatar
My 68 had a divorced choke on the intake and a choke delete "GM" plate on the dash bezel.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 06-16-2008, 08:36 PM   #6
68gmsee
Active Member
68gmsee's Avatar
A lot of the people that bought these trucks hated automatic chokes. Especially the older guys. They were used to trucks having a manual choke and they wanted the control.
My 68 came with a manual choke on the cluster and my 69 had an add on when I bought it.
The older automatic chokes were controlled by a coil on the exhaust or intake manifold with a link to the choke. They weren't super reliable. Newer trucks had the electric one installed which was a little better. But even then, some guys would disconnect them and install a manual one.
My dad was one of those that didn't like auto anything in a car or truck.
68gmsee is offline   Reply With Quote
Old 06-17-2008, 04:48 AM   #7
'68OrangeSunshine
'68OrangeSunshine's Avatar
I guess I'm one of those old guys who hate automatic chokes. I retrofitted one from LMC onto the Carter AFB 600 CFM in my '71 Jimmy. I drilled out a hole in the plastic dash bezel and used the factory mounting hole.
It looked stock under the Wiper knob, like a '68, almost.
The LMC choke cable came apart after 9 years where the ferrule gets
crimped to the cable sheath. I screwed it up trying to fix it. So now I have a new one on order.
A cable with a "C" on the knob would be from a '66 or earlier Chevy, or just generic. I understand you can still get one from the John Deere dealer. Go figure.
One reason I prefer a manual choke is that the automatics sometimes go off at the wrong time and/or won't go on when you do need it. Especially if you go around in mountains and deserts where extremes of temperature, altitude and atmospheric pressure can change rapidly.
Old 06-17-2008, 06:55 AM   #8
caminokid
Chevy nut
caminokid's Avatar
My 69 stepper has a choke cable my brother put in....backwards! Out is off and in is on...go figure! I have seen where it was a dealer installed item.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 06-17-2008, 10:15 AM   #9
68gmsee
Active Member
68gmsee's Avatar
Hopefully you won't loan it out to a buddy or relative and forget to let them know. Gas is expensive these days...
If you have a fishing boat, don't ever let him rewrap you steering cables. My brother in law did that once and wrapped them backwards. Turn to the right and boat went left. Darned near killed us!
Old 06-17-2008, 08:00 PM   #10
caminokid
Chevy nut
caminokid's Avatar
Dont have a boat...hes better at boats then I am.
But...thats funny right there!! I dont care who you are!!
Old 06-18-2008, 09:33 AM   #11
jdodd68
jdodd68's Avatar
Yeah the guy before me but a cable on the passenger side right in line of where the choke is on the carb. I figured that wasn't stock.
50th Anniversary 1968 Chevy C10 Custom LONGBED FLEETSIDE
350 out of a 70 chevy
Facebook
jdodd68 is offline   Reply With Quote
