Old 05-13-2008, 03:41 PM   #1
acl
acl's Avatar
radio questions
my sons 68 has factory radio. when on and warm you can barely hear a little static. Radio or speaker problem???? any quick way to tell? any suggestions on a replacement if needed. do not want to cut dash. anyone have one with i-pod plug in. Thanks
Gary
acl is offline   Reply With Quote
Old 05-13-2008, 04:39 PM   #2
Luis_gz06
Luis_gz06's Avatar
Re: radio questions
Could be the antenna too not getting any frequency. Have you checked your antenna if its plugged in correctly?
1972 Chevrolet Blazer 4x4 (Almost done stay tuned)
1970 Chevrolet Pickup Longhorn CST/20 (SOLD)
Luis_gz06 is offline   Reply With Quote
Old 05-13-2008, 04:48 PM   #3
acl
acl's Avatar
Re: radio questions
good idea, have not checked. just told radio did'nt work when he bought it
Old 05-13-2008, 06:49 PM   #4
Putter
More Cowbell....
Putter's Avatar
Re: radio questions
Speaker is my vote....especially if it's the factory one.
Just attach another speaker and test
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 05-13-2008, 06:55 PM   #5
prg machine
prg machine's Avatar
Re: radio questions
After checking everything out you will probably discover it is the radio. I have several just like the one with the symptoms of yours. there are lots of people out there who rebuild these radios.
69 K-20 cloned to a 67 with front clip and some other stuff.
383 .040 over
Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears:
prg machine is offline   Reply With Quote
Old 05-13-2008, 06:57 PM   #6
Mint68
Mint68's Avatar
Re: radio questions
You can get a factory am/fm that has been fixed to allow an ipod to plug into it, but they are going to be at least $500. If anything, stay away from autosound, they are garbage!
Mint68 is offline   Reply With Quote
Old 05-13-2008, 11:13 PM   #7
Luis_gz06
Luis_gz06's Avatar
Re: radio questions
Eighter the speaker or antenna. When I intalled my factory radio, the same thing happened, no sound, just static sounds when it was all the way up. I checked the antenna and found out it wasn't hooked up properly. I fixed it and it started working right away. I even had to turn it down some cause it got loud.
