trailing arms are they all the same long short bed??
Okay so I need trailing arms.. I have a SWB and i am curious if the long bed ones are the same? I am going to look at some long beds that are being parted out and I am curious if they are the same as the SWB.. thanks in advance.
Project "Edna Marie"http://www.67-72chevytrucks.com/vboa...74#post5998074 Toys: 2014 Dodge Ram 1967 SHORTBED |
Retired Air Force Veteran
![]() Join Date: Aug 2007
Re: trailing arms are they all the same long short bed??
If I remember right, yes they are the same size. Someone will chime in to confirm this.
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
![]() Join Date: Dec 2007
Trailing arms are the same for both.
They're the same length. The differences would be for 3/4 ton trucks as they had reinforced trailing arms (ECE sells a reinforcement kit that does the same thing).
![]() Join Date: Mar 2005
will the 3/4 ton trailing arm work on the 1/2 ton without mods??
Yep.
its all about the +6 inches
yes, and they are a bit stronger too.
Thanks guys that is all great info so best case scenario they are 3/4 tons
![]() Join Date: Jan 2008
I believe they are different lengths.The difference in long and short is 20".The front is 10"shorter and also 10" in the rear. Unless they move the main crossmember 10" rearward,the arms have to be longer. 10" or so.Chime in and let me know if I'm right or not.
Roadtrip!
![]() Join Date: Feb 2003
Short and long bed should be the same. I would guess a burb would be the same also, but not positive on that one.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
All trailing arms are the same length..
69 Lwb C-10 402/700R4 70 Lwb C-10 250/3pd Wisc. |
swb or lwb = same
#13 | |
