Old 05-13-2008, 07:33 PM   #1
hollywood68
rear mount gas tank and airbags...
Want to verify location of the rear mount gas tank when swapped on a 68 LWB. I have a bag system ready to go in and the air tank will fit perfect at the very rear of the frame behind the rearmost crossmember. From what I have found this should still leave me room for the gas tank swap I plan on doing once the bag system is in.
The best pic I have found to tell me where the tank fits is the final pic in this thread...
http://67-72chevytrucks.com/vboard/s...ht=blazer+tank
If anyone has any additional pics or can help me verify that an air tank will fit between the rearmost crossmember and the rear bumper (with room for the gas tank) that would be awesome.
thanks
hollywood68 is offline   Reply With Quote
Old 05-13-2008, 08:01 PM   #2
jimmydean
jimmydean's Avatar
Re: rear mount gas tank and airbags...
I had a 5 gallon tank mounted between the crossmemer and where the bumper would have been.
I still had room for a Blazer tank as far as I know, but I didn't get that far.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 05-13-2008, 08:15 PM   #3
SCOTI
SCOTI's Avatar
If the air tank fits behind the rear-most crossmember & a blazer tank fits in front of that crossmember & there should be no interference issues. I installed a blazer tank in my 68 & that c.member is in the stock location.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-13-2008, 08:49 PM   #4
hollywood68
thanks guys, I was 99% sure from some searching I have done but wanted to be 100% before I started making the mount for the tank.
