what backspace to use on the front..
im going with a 15x8 wheel in the front and I need to know what backspacing to use,
my 68 was converted from 6lug to 5lug in the front, so it has 5lug rotors/calipers in the front.. these are my options on the 15x8 wheels 5 x 5.5 5 x 5 5 x 4.75 5 x 4.5 thanks for the help... ![]() by the way i have stock rally's in the front and would like to go with that same backspacing, does anyone know what backspacing is on the stock wheels?
1971 C-10 SWB - LS swap w/4L60e, 20x8.5front 20x12rear, 1968 C-10 SWB - 454 BB TH350 -Gone! Last edited by ap2002; 05-13-2008 at 09:01 PM. |
Re: what backspace to use on the front..
anyone??
1971 C-10 SWB - LS swap w/4L60e, 20x8.5front 20x12rear, 1968 C-10 SWB - 454 BB TH350 -Gone! |
Tasty Cakes!
Couldn't you just measure the backspacing on your stock wheels? Offset
I'm a little ![]() ![]() Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado |
Yep, just pull a wheel off the truck, deflate the tire, lay it on the ground hub side down, stand on the wheel to make sure it contacts the ground evenly, measure from the mounting surface to the ground. There's your backspace.
And it'll be 5x5" if it's a factory rotor or axle. From the back of one stud to the center of one across from it. All others are measured center to center except five lugs. I know, WTF? But they are measured differently, I've won a few bets that way. Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! ![]() |
thanks for the info guys! sorry if I ask too much questions, im a noobie but am trying to learn about these trucks...
thanks again...
Tasty Cakes!
NP, I'm still a noob too. But I learn more and more every day!
