11-05-2002, 03:16 AM | #1 |
Speedo Calibration
I don't know squat about tranny's, so I was wondering how to recalibrate the speedo. I know my 72 GMC Super Custom is running about 7mph faster than what the speedo reads. I am running 255 70 R15 tires on my truck and I know that has something to do with it. How do I compensate?
Aaron Ventura, Ca. 1972 GMC Super Custom SB350/TH400 |
11-05-2002, 05:53 AM | #2 |
If you pull the current speedometer driven gear out of your transmission you can change it out and by adding or subtracting 1 tooth to the new gear you buy you change the speedometer reading up or down by approx. 5 mph. The new speedometer driven gears are available at your local GM dealer. By adding a tooth you increase the speedometer reading by subtracting a tooth you decrease it.
GMCPaul |
11-05-2002, 10:46 AM | #3 |
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
11-05-2002, 11:03 AM | #4 |
take to a tranny shop that specializes in calibrating should only cost 50-100 depending how much they wanna rip ya off thats still cheaper than alot of speeding tickets....I got a ticket last friday for doing 10 over when my speedo said i was doing the limit....well thats 86 bucks to the cops and not put towards my truck .........just my 2 coppers here
67 C/20 camper special 350 |
11-05-2002, 01:17 PM | #5 |
L.E.D. Freak
Not everyone knows that AutoMeter makes a new electric speedo cableless speedo. It's very easy to calabrate go 60 on the speedo, hit a button on the back when you pass a mile marker, and once again when you hit the next mile marker, done perfectly accurate, and if you change gears or tires, you can recalibrate with the touch of a button. Nice
Specializing in Custom L.E.D. inserts. http://www.ccled.com/ Contact me @ blazer2wd1972@hotmail.com (406)675-8082 or Joel @ jmcwaters@eps-corp.net 1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL |
11-05-2002, 02:33 PM | #6 |
For finer calibration, you can also go up or down a tooth or two on the "driving" gear -- the ring gear that's mounted on the tailshaft. Obviously, this requires dropping the driveshaft and pulling the tailshaft housing, but I did both the gears on my TH-350 in a couple of hours.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
11-06-2002, 09:22 AM | #7 |
1969 Custom 30 wrecker
Here's a good page to help figure out which gears you'll need:
http://www.chevelles.com/shop/speedo.html Although it's for Chevelles, it's the same for trucks too.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
