Whats The Deal With The Second Brake Pedal Switch With The Vacuum Line Going To It? Is It The Cruise Nock Off Switch?my 85 Truck Just Has The Vac Line,but My 88 Blazer Parts Doner Has The Vac Line And Two Electrical Plugs To It???????can't Seem To Find Any Info On This Switch!!!!!!! Thanks
In the Forgotten far North.
![]() Join Date: Jul 2007
Re: Brake Pedal Switch,what Is It?????????
That's exactly what it is. The older models had a secondary vacuum switch mounted above the dual connector brake switch.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
#3 | |
Parts and more parts
THANKS!!!!!!!So,if I am not going to use the cruise I can eliminate it or doe's it have to work in conjunction with the brake switch?Thanks
You can use it without the vacuum connection or just put one on that is a brake switch alone. The vacuum part is a vacuum breaker to get rid of the "seal-in circuit" when you have your cruise engaged. That way when you hit the brakes the cruise shuts down.
