Old 05-14-2008, 02:57 AM   #1
chrislehr
Engine n00b
chrislehr's Avatar
powerglide to 700r4
I need help building a parts list, and I know this is a fairly common swap, so run through what all you needed?
700r4 - looking for pre 73 if possible
TC
Do I need a new shifting unit in cab? New indicator? What do I need there?
kick down cable?
shortening (or lengthened) driveshaft?
Upgrade U joints while yer down there?
What else?
chrislehr is offline   Reply With Quote
Old 05-14-2008, 04:51 AM   #2
1tigers
Re: powerglide to 700r4
1982 was the first year for a 700r4 there are no pre73.
1tigers is offline   Reply With Quote
Old 05-14-2008, 02:43 PM   #3
70GMCer
70GMCer's Avatar
Plenty of write ups for this swap. Just do a search.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 05-14-2008, 04:32 PM   #4
68gmsee
Active Member
68gmsee's Avatar
Quick FYI... I read where you want to get the late 1986 or newer ones because of some problem with the earlier models.
68gmsee is offline   Reply With Quote
