Old 05-14-2008, 04:50 AM   #1
xmitsu10
xmitsu10's Avatar
Wiring Harness...who makes?
I've been looking to purchase a dash harness and had narrowed my choices to American Autowire (AAW Factory Fit from Musclerodz) and M & H from GMCPauls. I had downloaded the AAW and M&H catalogs and just noticed that they both use the same harness part numbers in their respective catalogs.
So now what I'd like to know is who actually makes the harnesses, AAW or M&H? Anybody know for sure?
Mark
71 Cheyenne SWB
xmitsu10 is offline   Reply With Quote
Old 05-14-2008, 06:22 AM   #2
HoupPhotography
Re: Wiring Harness...who makes?
Just curious, if it's the same harness, why does it matter?
R.I.P. Scott Kalitta
HoupPhotography is offline   Reply With Quote
Old 05-14-2008, 09:50 AM   #3
Select
Friday's Toy
Select's Avatar
I just put all new M&H harnesses in my 68. They were very well made and straight forward. I ordered mine with the HEI upgrade, but I still had to put a jumper in on my voltage regulator plug to get my one wire alternator to work. If I remember correctly it was from brown to blue and it works like a charm.
68 C10, SWB Fleetside with a 454, Turbo 400 and 4.11 posi....Exxon/Mobil loves me.
2009 Jeep Rubicon
2011 Powerstroke FX4 (totaled)
71 C10, SWB Fleet with factory tilt
72 LWB C10, 350 700R4 with factory tilt
Select is offline   Reply With Quote
Old 05-14-2008, 09:55 AM   #4
El Jay
Gone to greener pastures
$'s.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 05-14-2008, 10:53 AM   #5
HoupPhotography
Originally Posted by El Jay View Post
$'s.
Thanks El Jay, that is defintly something worth considering.
Old 05-14-2008, 01:44 PM   #6
xmitsu10
xmitsu10's Avatar
If you buy direct from the "manufacturer", the prices are the same. But with different vendors on this board who sell AAW and M&H, the prices are different, not by much but $60 is $60. I guess like you were curious as to why it matters, I was curious as to who actually made the harness. I've nothing but good about both AAW and M&H and now I know why.
Mark
71 Cheyenne SWB
Old 05-14-2008, 02:16 PM   #7
70GMCer
70GMCer's Avatar
Too my knowledge, M&H makes there own harnesses. Maybe they sell them to AAW. I started using M&H years ago, and have never had any problems. I bought mine from http://www.mothertruckers.net/
I think he might be a vendor on here as well. I found his wiring prices to be better.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 05-15-2008, 08:29 PM   #8
Musclerodz
Long story short, M&H and AAW used to be partners many years ago and today each are manufacturers of their own products. Price between the two are kept almost identical. Deals are to be had through their dealers. If you call us, we will give discounts to board members.
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 05-16-2008, 02:25 AM   #9
xmitsu10
xmitsu10's Avatar
Thanks Mike. I knew you would have the answer. So are they the same or different harness and if they are the same, which one makes them? I know it's not very important as I have heard great things about both, just curious.
Thanks,
Mark
71 Cheyenne SWB
Old 05-16-2008, 02:52 AM   #10
Musclerodz
Thanks,
Mark
They both make their own original harnesses and there is no difference when looking at the two. The differences in the companies come with some of the other products they carry. AAW has been our favorite because of their Update Harnesses and customer support has been excellent so far. We also use their products regularly and have had zero issues so far.
Mike Redpath
Old 05-17-2008, 12:48 AM   #11
71 super
71 super's Avatar
I havecomplete M&H kit in the 71 and have no issues. Also have complete set of AAW for the 72 no known issues -truck is still apart so it may be a while, why 1 one each? I used a different vender for the second set and they now carry only AAW. Price is good pats match what I took out - same stuff.
71 super is offline   Reply With Quote
Old 05-17-2008, 12:58 AM   #12
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Not to upstage any member or vendor, but I bought my harness directly from M&H. They are on the web at www.wiringharness.com. Helpful folks if you need to talk to them on their 1-800 number, too.
Member Nr. 2770
Old 05-17-2008, 01:27 AM   #13
Sammy
Do the under dash harness have all the correct connectors or do you have to pin everything?
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 05-17-2008, 03:07 AM   #14
byrd
Union Electrician
byrd's Avatar
Everything I have purchased from M&H has been top shelf and a perfect fit, factory look.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 05-17-2008, 03:56 AM   #15
xmitsu10
xmitsu10's Avatar
M&H has an underdash harness that has all the factory connectors but uses the the new style ATO blade type fuse block instead of the factory glass type fuse block. That's what has led me to M&H.
Mark
71 Cheyenne SWB
