Old 05-14-2008, 07:49 PM   #1
lyrikz
PITbut
lyrikz's Avatar
Spray on rust preventer????
Im finishing up some rust repair on my truck.. On the doors specifically. I need some kind of spray on rust preventor. I have heard of this stuff called body wax???...
Anyone know what im talking about... Just something i can put over the areas that see the most abuse.... Kind of like a 3rd layer of protection...
Heres a pic for you guys.
one of the rusted areas.... See my build thread for more goodies. ahaha..
lyrikz is offline   Reply With Quote
Old 05-14-2008, 08:11 PM   #2
92306HO5
92306HO5's Avatar
Re: Spray on rust preventer????
try eastwood products.trucks on power tv had a spray on product that protects bare metal up to a year that they were using on their project 65 chevy truck.maybe search on their website as well.
92306HO5 is offline   Reply With Quote
Old 05-14-2008, 08:17 PM   #3
IAFF2407
IAFF2407's Avatar
I once asked a body shop what they did for the inside of the doors and that is what they told me they used. I don't know how long it lasts or any other info on it.
Al.
1972 GMC Sierra
1972 GMC Super Custom Suburban
IAFF2407 is offline   Reply With Quote
Old 05-14-2008, 08:30 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
Look at the Rust Bullet product. www.rustbullet.com
It makes one hard shell on the metal that you are spraying and it is just about the same in the price lines.
piecesparts is offline   Reply With Quote
Old 05-14-2008, 10:31 PM   #5
jimmydean
jimmydean's Avatar
I've used NAPA spray converter (called "Resore" I think), seems to work very well. Any trace of rust turns up black, the rest is clear. Cure for 24 hours, then top-coat, or don't.
I use it on the inside of doors and as a base coat before prime. Comes in rattle can, or brush on.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 05-14-2008, 10:37 PM   #6
my67chevytruck
Under Construction
my67chevytruck's Avatar
I'll share my secret with you. My friend has been using this in his restoration shop for years. http://www.gemrustkiller.com/ It was used on my '56 and i am using it on my son's 67.... It's run's about $12.00 a quart i believe, which comes in a plastic bottle with a sprayer you can attach. It is easily sprayed wherever needed.
Good luck with your Build i am now starting on the drivers side of my son's truck as well...
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 05-14-2008, 10:49 PM   #7
trjohnso
Guest
Posts: n/a
Looks like you have taken care of the rust by sandblasting, call PPG they make a spray on rust inhibitor you use under the primer.
