![]() Join Date: Apr 2004
Blazer window frame question. Nuts broken.
One of the nuts broke off of the inside of my window frame where the door rubber screws down (top). This is the part right above the vent window. how can I fix this with out cutting into my window frame to weld on another nut? I was thinking about use some of those clips with nuts on them, but I'm not sure where to find them. This is a pic of something similar to what I'm trying to find.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
Re: Blazer window frame question. Nuts broken.
My PO fixed it that way, but I don't no where to buy them, I plan to put a nutsert in it, since his fix hits the bracket for my soft top
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
![]() Join Date: Dec 2002
those are fender clips you have in the pic. they are available in most help sections. It has been several years but someone put up a link for nut inserts. I saved the link but it no longer works, Hopefully someone else will know
is this what your are talking about? http://img.alibaba.com/photo/5181708...t_Nut.summ.jpg
How do you get it to stay in the hole without falling down into the window frame?
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht Last edited by hotrodhomi; 05-15-2008 at 04:09 PM. |
#5 | |
Thats cool. I've never seen those before. They remind me of screw you put in your sheet rock. I fixed the problem. I found some clips at Kragen.
