Old 11-05-2002, 11:43 AM   #1
oteixeira
Question Help Picking new gears
Hi all,
I have a friend at work that has a '70 K-10 that was originally a 292 I-6 with a 4 speed crawler. He has done a "few" mods over time and it is now a 8" lifted 4x4 with 38s, and a 427. He left in the original 4 speed and axel gears.
The first question is based on the original setup what should his gears be from the factory? The second is what would you recomend for it? In 4th gear at 65 (a true 65), he is at 2K on the tach.
Any help is appreciated...
Orlando
70 C-20 Custom Camper
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=300251
oteixeira is offline   Reply With Quote
Old 11-05-2002, 11:59 AM   #2
crazy longhorn
Fabricate till you "puke"
I would say you need a 4.56 or 4.88 gear with the 38" tires. that will require a carrier change, as stock was likely a 3.07(3 series carrier). check this link for math to see what you want for rpms on the hyway..... http://www.smokemup.com/auto_math/index.php
crazy longhorn is offline   Reply With Quote
Old 11-05-2002, 03:21 PM   #3
ckhd
ckhd's Avatar
The standard ratio for a '70 K10 six w/a 4-speed is 3.73. Are you sure that it's 2000? Could it be about 2150? If you do the math with what you give, then the rear is around 3.50 (3.54). If you do the math for 2150rpm, then it's 3.73.
3.07 was an optional ratio. They would have had to specify just a 3.07 ratio, or it would have come with a 307 with a 4-speed, a 350, or a 396 with a t-400.
3.54 was also an optional ratio.
Since it was originally a six, it would have had to be ordered specifically as a 3.07. Check the glovebox.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 11-05-2002, 04:02 PM   #4
crazy longhorn
Oops, checking the math I come up with the same figures.....it sounds like 3.54s run 64 mph @ 2000 rpms on 38s.....
