PITbut
How do you remove pushloc fittings?
I got my suspension stuff in, and was messing around with the pushloc fittings.. I didnt see how they worked, so i pushed my airline in, and now i see how they work. ahaha. Anyway i can get that airline out of the fitting so i can install it the right way???
I didnt trim the line at the end so it was a nice 90 degree on it. Let me know. |
Chevy Truck Addict
![]() Join Date: Aug 2006
Re: How do you remove pushloc fittings?
There will be a "collar" on the fitting where the line fits in. Push the collar in and pull the line out... Should be pretty simple.
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
More Cowbell....
tin-snips!!!!
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
take an open end wrench the size of the tubing (1/4" - 3/8" - 1/2"-whatever) then use the open-end to "straddle" the tubing and push down on the collar while pulling the opposite direction with the tubing ... it should pop right out
Chevy Truck Addict
That's a good tip Shane... I never had problems removing them with just my fingers but if you had a stubborn connection, your method would work great.
