Old 05-15-2008, 10:19 PM   #1
crm318
Alright Alright Alright
crm318's Avatar
off the line performance question
i just reinstalled my engine with a new cam (.440/.440 212/212) and i took it to a long road to gouge on it. from a dead stop it could only chirp the tires. after that it would throw you in the seat like crazy. i took a turn and floored it and the truck when from side to side roasting until i let off (with an open rear). whats the deal?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 05-15-2008, 10:28 PM   #2
jhow66
jhow66's Avatar
Re: off the line performance question
3.07 gears.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 05-15-2008, 11:26 PM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
How does that compare to how it drove before swapping cams?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-15-2008, 11:56 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
Not enough info. tire size with those 3.07 gears (definitely to shallow of a gear ratio)
What is your timing set at and how soon does your advance come into play?
piecesparts is offline   Reply With Quote
Old 05-16-2008, 01:33 AM   #5
crm318
crm318's Avatar
it performed about the same. the tires are 275/60/15. i have it set at 12 degrees timing. this isnt a complaint really the truck performs exceptionally well. another issue is that the truck performs sigificantly better when i manually shift it (not just the shift, it pulls harder in between gears).
1972 Cheyenne
Old 05-16-2008, 01:45 AM   #6
Billla
Billla's Avatar
It's a pretty open question, but my immediate thought would be the need to invest in a torque converter...
Billla is offline   Reply With Quote
Old 05-16-2008, 02:21 AM   #7
HavinSomeFun
Still Just Havin Some Fun!
HavinSomeFun's Avatar
I second that. I have a 2200 stall in mine and its not even close for what I need to move all that weight off the line.
a green one with some stuff done to it....
HavinSomeFun is offline   Reply With Quote
Old 05-16-2008, 02:31 AM   #8
piecesparts
Well, 3.07 gears with a 28" tall tire, is the worst part of the situation. The timing at 12 degrees is a fair setting, but you could work that one a little more and get more out of your engine combo. I would look at maybe timing your engine with a timing light that has an advance feature and see if you can get the engine to run with a "Total Advance" of around 35 degrees. Look at a set of 3.73 or 3.42 gears for a better bite. The torque converter would be important only if you are experiencing a phenomenom of the engine pulling the truck through the stop light when you are sitting at it waiting for it to change. The torque converter change would do a couple things here, First it would allow you to build more RPMs before the tranny pulled your motor down and Second it would allow you to sit at that stop without having to have a possible high idle for the camshaft and thus keep you from riding the brake. It would allow your tuning of the carb to stay out of the "transition circuit" and more into the idle circuit.
Old 05-16-2008, 03:25 AM   #9
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
and/or a lower set of gears and a posi.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
