Old 05-15-2008, 10:37 PM   #1
edin355
fastburn heads
I have a set of complete new aluminum gm fast burn heads for sale. $700 plus shipping. these are new heads in the box.You can go to any site that sales heads and get the low down on them.edin355
edin355 is offline   Reply With Quote
Old 05-15-2008, 11:33 PM   #2
meathead95
computer illiterate
meathead95's Avatar
Re: fastburn heads
whats the part number?
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 05-16-2008, 01:22 AM   #3
Billla
Billla's Avatar
Re: fastburn heads
I believe the P/N is 12464298; if this is the case, then these a screamin' deal on some great heads for a mondo 350 or strong 383/400! "Fast Burn" has been applied to a bunch of different castings, however...
From the GMPP 2008 catalog:
When it comes time to own the street, this is the head for you!
GM Performance Parts has brought together all of our new
technologies to create the ultimate 23˚ small-block GM cylinder
head. Fast Burn technology maximizes combustion of the air/
fuel mixture, resulting in higher cylinder pressures and more
power production. The combustion chamber (62cc) is designed
for flat top pistons, and the head requires no additional porting for
optimum performance, so it provides maximum “out-of-the-box”
performance. Recommended for any standard coolant flow 1955–
2000 283–400 cubic inch small-block, the Fast Burn head helps
us make 425 horsepower from our own ZZ383 crate engine!
• CNC-machined aluminum performance head
• Completely assembled with 2.00"/1.55" valves
• 210cc intake port, roof raised .240"
• 78cc D-shaped exhaust ports, raised .200", requires
Fel-ProŽ gasket #1470 (may require minor trimming)
• 62cc combustion chamber, .400" thick deck (can be
milled safely .060")
• No heat riser
• Angled spark plugs (5/8" hex, 3/4" reach, tapered plugs)
• 1.48" Valve spring seat diameter
• Use head gaskets with stainless steel fire rings
• Raised, machined rocker rails
• 0.530" max valve lift (without modifications)
• Screw-in studs, (3/8" top, 7/16" bottom)
• Dual bolt patterns for perimeter bolt and center-bolt
valve covers
• Dual bolt patterns for both Vortec and early model
intake manifolds
• Use production intake gasket P/N 12529094 for Vortec
intakes or dual bolt pattern intake gasket P/N 12497760
for either early model or Vortec design manifolds
(Fel-ProŽ #1289 and #1207 may be used)
Billla is offline   Reply With Quote
Old 05-16-2008, 03:26 AM   #4
edin355
Re: fastburn heads
Billla somes it up. Thanks Billla for your input. These are new in the box. Satisfaction gauranteed.edin355
Old 05-16-2008, 06:37 AM   #5
lindsey
Re: fastburn heads
Are you willing to ship these to AZ??? I am interested.
lindsey is offline   Reply With Quote
Old 05-16-2008, 01:59 PM   #6
edin355
Re: fastburn heads
Yes I would be willing to ship to AZ. I will find out the shipping cost today and get back with you. thanks edin355
Old 05-16-2008, 02:34 PM   #7
FormerMember
Re: fastburn heads
2nd in line. Shipping to 03036 please.
FormerMember is offline   Reply With Quote
Old 05-16-2008, 04:17 PM   #8
edin355
Re: fastburn heads
Shipping to AZ would be about $55 for a 3 day shipping.Hope this helps you out. edin355
Old 05-16-2008, 04:22 PM   #9
edin355
Re: fastburn heads
Shipping to you would be about $55. edin355
Old 05-16-2008, 04:39 PM   #10
FormerMember
Re: fastburn heads
Thanks. I'll take them, if it comes to me.
Old 05-17-2008, 06:29 PM   #11
edin355
Re: fastburn heads
If I havent heard from lindsey by the end of today the heads will be yours. We can get together and make the necessary arrangements to get them to you. edin355
Old 05-17-2008, 06:33 PM   #12
FormerMember
Re: fastburn heads
Sounds good. They will go well in my GMC.
Old 05-18-2008, 07:18 PM   #13
edin355
Re: fastburn heads
The heads are yours for the taken. edin355
Old 05-18-2008, 11:46 PM   #14
FormerMember
Re: fastburn heads
I responded to your PM
Old 06-08-2008, 02:05 AM   #15
edin355
Re: fastburn heads
Just wanted to say thanks to Billla for help on this.I really appreciate his help. And thanks to grendal. I hope the heads bring you what you expect.Will be waiting to hear how things go. edin355
