Retired Air Force Veteran
![]() Join Date: Aug 2007
Electric Fan and Transmission Cooler Mounting
Need some advice. I am going to continue to run a regular fan with clutch in my truck BUT want to also running an electric fan. In addition, I'm going to install a transmission cooler. They both fit in front of the grill but I like the way it looks - unbalanced. Will I be able to run the electric fat centered in front of the radiator and the transmission cooler centered on the inside of the radiator in front of the clutch fan? Not really sure how all of that works out.
The electric fan will be on an auxiliary switch and probably only used as a backup if the temp rises. Your thoughts? Thanks, Harry
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
Re: Electric Fan and Transmission Cooler Mounting
I think that if your are going to keep using a clutch fan, then the electric fan will only inhibbet the air flow through the radiator. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
Good Point Wes. As for the transmission cooler, centered or offset and which side of the radiator do you suggest? Thanks, Harry
I always run the tranny cooler on the right side of the radiator. No particular reason, just because the cooling lines are routed that way. WES
Parts and more parts
Ditch the clutch fan and go with the electric--get one big enough for your needs. I changed out the fans on two of my trucks and gained some MPG and smoother idles. The tranny coolers on my trucks are on the front side of the radiator in the lower right corner. I chose ther, because it is close to where I tapped into the radiator cooler connection.
I agree with the electrics, that is why we manufacture a kit for the 67-72s and now Delorians. Lots smoother and quicker RPMs too. WES
Thanks guys for the advice
i put an electric fan from a 95 firebird and a serp kit from a 4.3l on my v8 and even idling thru town the temp never gets over 190 i worry some times it isnt getting hot enough--ditch the clutch fan
*SOLD* 1968 Chevy SWB Fleet 350/350 combo Tach/tilt/buddy buckets Bagged/18" Wheels Black on Black ![]() Project "Pandemic" the Farm Rat 1927 Chevy Capitol Truck Rat rod '30 Model A Frame Dual Carb 5.3 LS http://www.67-72chevytrucks.com/vboa...d.php?t=804162 2007 GMC 4 DOOR 2WD BUILT 5.3 STAGE 3 CAM 93 TUNE LIFTED 22X12 WHEELS 33" TIRES 2023 Jeep RENEGADE Wifes ride |
