Old 05-06-2002, 02:15 PM   #1
Fast68Chevy
Fast68Chevy's Avatar
Post damn radiator cushions...
who here knows if the bototm cushions for radiator tanks in the rad support are supposed to be the oens with or without the nipple thingy on thwe backside of them ? there are two size of them and neitehr ones iwl fit in the cups in the support correctly
dammit.,
thanks for anything
Randy- Lincoln, IL
randy@ccaonline.com 2177353230
*many GM parts bought, traded, or sold -am parting out: '81 Cutlass Supreme Brougham
current fleet: -71 C-10 350/CH465/3.07- basketcase, #1
-90 Cavalier 2.2L sky blue, driver, was free
-84 Z28 5.0L/700R4/3.73 daily driver
-84 Firebird/SE 2.8L/T-5/3.73/engine bad, project #2
-82 purple Trans Am, project #3
*Paint is overrated*
© RSS Enterprises 2000
Fast68Chevy is offline   Reply With Quote
Old 05-06-2002, 02:42 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
Post
Not sure if I follow you. Are you asking about the rubber insert or the steel insert housing?. The steel housing size varies in size and location depending on side of radiator and engine installed. The rubber piece just presses into the housing, there is no nipple on it. The housing is riveted at the factory. If you need som 4 core ones, I may have them. You'd have to remove rivet and bolt them onto your support
Jeff Jesseman
Cheyenne Parts Northeast
Franconia, NH
67 Chevy SWB Fleetside
70 GMC Burb 1/2 ton 2wd
72 Chevy Burb 3/4 ton 4x4
Parts bought and sold
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 05-06-2002, 03:18 PM   #3
Mixup
Post
I just bought some from Brothers. They list the bottom bracket as being the same on all radiators and just the rubber insert as being different. The top brackets are listed for HD radiator with different inserts. They all fit on mine. I switched to a HD radiator.
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
Old 05-06-2002, 03:32 PM   #4
texnician01
texnician01's Avatar
Post
your talking about nipples, cups, and support? sounds like you've got bigger problems man!!! LOL!!
on a serious note, I've only ever seen the rubber pieces to fit the four core and 2-3 core radiator. i've got a set for a 4 core if you need them, I think that they are ok. they're on the parts truck. I'll look in just a few minutes.
Nathan
1969 C-10 292 I-6 4 spd in the middle of a restoration. going to get a 327 and 3.07 gears but keeping all of the original parts so I can put it back to original later on down the road.
55 chevy 4 door 150
47 Willys CJ-2A
69 C-10, 340HP 327
55 chevy 4 door 150
47 Willys CJ-2A
05 Harley Night Train
06 1200 Sportster (Wife's bike)
70 Honda CL350
OIF2 & OIF7 Veteran
Nathan & Tiffany
texnician01 is offline   Reply With Quote
Old 05-06-2002, 04:32 PM   #5
Fast68Chevy
Post
i have no 4 core, i have 2-3 core, there are two styles i have here form past 67-72 trucks, the ones with a nipple deal on the bottom and the ones that go in the top brackets with no nipple deal
lol at Nathan lol i like nipples. yes but they have to be feminine ones, thank you anyways
so howcome i have nipple ones around here then for ? i like nipples and the word nipple alot, i dot know why, i just do. nipples.. damn.
lets introduce another word into here, rubber, yes I am talking about the rubber ones, not the metal housing thingies
thanks
[This message has been edited by Fast68Chevy (edited May 06, 2002).]
Old 05-06-2002, 05:07 PM   #6
texnician01
Post
ROTFLMAO so hard I could barely hit the reply button!!! lol!!
Nathan
69 C-10, 340HP 327
55 chevy 4 door 150
47 Willys CJ-2A
70 Honda CL350
OIF2 & OIF7 Veteran
Nathan & Tiffany
Old 05-06-2002, 05:17 PM   #7
Fast68Chevy
Post
you mean click not hit, actually, welll probably actually in all reality ya meant to type in flick as in a verb, you musta had a typo there, but i understand, its ok
ok never mind, i better move on before,,,
Old 05-07-2002, 03:30 PM   #8
Fast68Chevy
Post
mixup, are you saying that upper rubber cushions differ from lower ones ?
i gotta make sure and asap now, i need radiator installed pretty soon like now, onece i mount waterpump and alt and belts and exhaust of some kind, hmmm
thanks guys
Old 05-07-2002, 09:17 PM   #9
Fast68Chevy
Post
ttt
