Old 05-16-2008, 01:59 AM   #1
tjvending
tjvending's Avatar
Gas Gauge problems-
I having some gas gauge problems; Problem one, my needle fell off of the gauge and I got it back on. I put a new sending unit in because I couldn't get the gauge to read correct, its off. I let my truck run out of gas so I could tell where a empty tank would be. I then placed the needle to empty, I went and had ten gals of gas put in, it nows reads a full tank and and half. How do I get this read correct?
TJ
tjvending is offline   Reply With Quote
Old 05-16-2008, 02:05 AM   #2
HoupPhotography
Re: Gas Gauge problems-
My guess would be the new sending unit is a different ohm than the gas gauge, could of been the problem previously too. The stock gauge is 90 ohms and the sending unit should be the same.
R.I.P. Scott Kalitta
HoupPhotography is offline   Reply With Quote
Old 05-16-2008, 02:21 AM   #3
Sammy
When you disconnect the wire from the tank w/ key on it should drop to E. If that is true you could ensure U have a good GRD by adding a wire to each the gage panel & sending unit. Retrace wire from tank to dash. Only if you have the correct 90 OHM sending unit & gage.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 05-16-2008, 04:28 AM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Try this
http://www.6066gmcguy.org/Electrical-02.htm
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 05-16-2008, 07:07 PM   #5
tjvending
tjvending's Avatar
Does it matter where you place the needle if it fell off? Does the gauge reset itself if this happens. I thinking I don't have the needle in the correct postion
Old 05-22-2008, 09:55 PM   #6
tjvending
tjvending's Avatar
Does it matter where you place the needle if it fell off? Does the gauge reset itself if this happens. I thinking I don't have the needle in the correct postion. Its jumpimg all over. I did the unhooking of the wire at the tank and its go to full then I groung it and it goes to empty.
TJ
Old 06-06-2008, 12:45 PM   #7
tjvending
tjvending's Avatar
Needle fell off again, does it matter where you replace it back ? location.
TJ
Old 06-06-2008, 01:03 PM   #8
Mt Man Chad
Mt Man Chad's Avatar
Yes the clocking location does matter.
You can index it with a full or empty tank. Put some dielectric grease on the lead wire that plugs into the sending unit.
Also clean a small part of the tank behind one of the mounting bolts and threads for a good ground for correct resistance.
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
