Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Jetting foe Edelbrock 1406
Bought a used Edelbrock 1406 from a guy in Colorado,elevation 6500ft.
My elevation is about 600ft above sea level,Ontario,Canada He had it jetted and working well for his elevation. Just wondering where I should start as far as jets go. Carb is not for my Blazer it's for a future project.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
![]() Join Date: Aug 2004
Re: Jetting foe Edelbrock 1406
If he gave you the original jets/rods/springs that came in it new, I'd put those back in it. If not, try to find a manual and use the tuning info in the back. I wouldn't hesitate to get the calibration kit, it has a large selection of jets/rods/springs and you can get it dialed in pretty quickly once you have it installed and running.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
Under Construction
Hopefully this link will help you out. there is a link on this FAQ page to the owners manual as well. Good luck.
http://www.edelbrock.com/automotive_...carb_faq.shtml
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
![]() Join Date: Jul 2004
Heres some quick specs for the 1406 - main jet .098 - metering rod .075 x .047 - rear jet .095 - step up spring = yellow.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
Thanks boys,
I do have the owners manual and was also looking at the one on Edelbrocks site after I had posted.Some great info. there. I havn't torn into the carb yet so I don't know what jets are in there.I'm sure they are alot leaner than I need. Unfortunately he did not send the stock jets etc.
Do the colors of the springs fade?
I tore the carb apart to get the jet #'s(hard to see BTW) and the step-up spring is the natural steel color no hint of the stock set-up yellow. The main and secondaries jets were the stock .098(main) and .095(secondary) Metering rod was also stock with a # 7547 stamped on it. Here are a couple pic's. Pretty clean unit. ![]() ![]() ![]() ![]() Here's the metering rod. ![]() Main jet,really hard to read the numbers.I used a magnafying glass to decode the numbers. ![]() Secondary jet. ![]()
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 05-16-2008 at 08:00 AM. |
Broken Down
Not to bad at all!!
kenm78 1982 Chevy 4X4 Project truck ![]() ![]() ![]() ![]() “It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt” |
![]() Join Date: Feb 2002
[QUOTE=BobbyK;2724447]Do the colors of the springs fade?
Yes. And they can also lose their temper over time and compression. A new spring kit, p/n EDL 350- 1464 [multiple colors] would give you fresh springs and tuning options for $8 at Jegs.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 05-16-2008 at 01:40 PM. |
