05-16-2008, 07:16 AM | #1 |
3/4 ton drop requirements
What do you all feel about spending time and money on dropping a 3/4 ton ? I'm ready to buy tires and am thinking about doing all the other stuff as well, which means different wheels, tires, drop kits, etc. Is a 3/4 ton truck worthy of such an expenditure ? It looks like all 1/2 tons doing this kinda stuff.
05-16-2008, 07:20 AM | #2 |
Re: 3/4 ton drop requirements
Welcome to the board!!!
I say go for it! It will set you apart from the crowd. There are tons of sweet 8 lug wheels on the market now-a-days too
CHEVY ONLY |
05-16-2008, 07:25 AM | #3 |
I'm sticking with my 16 inch steelies, painted white with moons and trim rings. So you think it's not a waste to spend time on a 3/4 ton?
05-16-2008, 08:40 AM | #4 |
i don't think so.
not sure what the after-market is like. might cost you more to drop the 3/4.
CHEVY ONLY |
05-17-2008, 06:55 AM | #5 |
Between Trucks...
GMC Pauls has drop coils for 3/4 ton trucks.
Beat it to fit, Paint it to match... |
05-17-2008, 07:09 AM | #6 |
i am dropping my 3/4 ton. my plan is to still retain towing and hauling capacity since it will still be used as a truck but making it look better. this is my plan: putting drop spindles on the front (maybe $60 more for the 3/4 ton) and maybe half a coil cut off the spring to get the stance i want, removing 5 leaves out of each side leaving 4 in but installing a helper bag kit from firestone ($240 from summit) that way i kind get it lower and still be able to haul. i'm am also going to retain my steelies (note- if you find baby moons that will fit you're my new best friend because i've been looking for months and can't find anyone that makes them to fit 11 3/4" inner diameter). anyway i should end up with a 3/4 drop -ish.
i looked into shackles and hangers and an axle flip. i took some measurements and i have roughly 7" of clearance from the tip top of the differential cover to the bottom of the bed floor. shackles and hangers and an axle flip would give me 6" of drop and only 1" of travel before i had a nice dent in the floor of my bed shaped like the top of my diff and i really don't want a hole in the floor. i could go with just the shackles and hangers but don't know how much i trust them for hauling. hope it helps a bit. answering your question if it's "worth" it? well, i don't like answering a ? with a ? but the question to you is "is having a b*tchin truck worth it to you?"
It's peanut butter jelly time. '74 GMC 3/4 TON 2WD LB Last edited by randyjohn; 05-17-2008 at 07:09 AM. |
05-18-2008, 06:10 AM | #7 |
Throw that truck on the ground! I want a low slung 8 lug, but all I have is 1/2tons.
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
08-17-2008, 10:48 PM | #8 |
Somebody show me a place that makes 3/4 Ton 73-Up spindles please. I haven't ever seen any.
08-17-2008, 11:24 PM | #9 |
yes go for it, i have a 60 1/2 ton that i am going to put all 3/4 ton stuff on the front x-member and the 14 bolt rear. i will be lowering it soon also so why not drop a 3/4 ton truck.
vinnie 1960 chevy c10 frame with a 1966 cab 2002 dodge intrepid r/t 2004 chevy 2500 4 door short bed |
08-18-2008, 01:40 PM | #10 |
Java Mechanic
I'm going to bag the rear of mine and expect to run a bit lower than stock height. I may drop the front with spindles.. haven't decided yet.. I'm woring back to front and I'm still a good $10k from the front end of the truck at this point... lol
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
08-18-2008, 09:04 PM | #11 |
i have the drop spindles 3in and 5in springs. got every thing from spindles to springs from airbagit.com(some say they sell crap but i have not had any problems for the last 3yrs) and the shocks for the back. everybody likes the look and gets a kick when i tell them its a c20 8 lug. too bad am selling my truck. if you search you might find some pics long time since ive posted.
08-18-2008, 11:42 PM | #12 |
I can't address the 'worthy' ness but I did a 68 3/4 lowered abunch of years ago and it was a blast. Every old guy on the planet either wanted to buy it or talk about it. I used late model factory ford steel wheels and chrome lug nuts, 235 front tires and I think the rear was a Michelin from a land cruiser, nice and tall and wide to boot. I always bought used tires form a buddy at one of the local tire stores, so who knows what I was going to get.
The front lower control arms were from a guy in Oregon, I think, that made a raised balljoint lower front control arm, worked great, cut the coil a little easy lowering done at home. I don't remember the rear, but I did learn that if I was going to do it again, on a coil rear, to use a Suburban rear lowered coil to keep the load capacity up. The truck was cool, the guy I sold it to used it to haul his sprint car and I heard it became his push start truck too. I kind of miss that truck, I hauled a lot of $hit in that old blue truck. Mick |
08-19-2008, 12:12 AM | #13 |
Here is the 1967 fleetside C20 my son and I are doing.
http://67-72chevytrucks.com/vboard/s...d.php?t=252364 We are pleased with how it's coming along. The frame is all done and the next biggest hurtle is getting it through the body shop. Then we are going to drop in a gen III engine & 4L60E. Not at all worried about the value because we know it is unique and is being built very clean. Having alot of fun and really appreciate having this board as a resource of information. Last edited by rcrahn; 08-19-2008 at 12:13 AM. Reason: add link |
05-15-2010, 12:10 PM | #14 |
C20 owner needs C20 drop spindle information, Where specifically did you purchase the 8 lug drop spindles? There is one company thats selling the whole kit & not just the spindles. Im assuming that buy purchasing this complete set up it will change say a 1969 to a 1973 8 lug set up? I already have the 8 lug disk brakes we just need the spindles.
