MSD box mounting on heater box?
I did this a while back when I was just trying to get it finished. Do you think it will be alright? I thought it was fine, but now im not really sure if I trust it. The thing is, There arent many places open to mount it.
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
Rollin 16's son!
Re: MSD box mounting on heater box?
I mounted mine on the firewall right behind my distributor... The only better solution I could think of is mounting it somewhere flat or maybe inside the cab?
1969 lwb custom camper ![]() "The safest way to double your money is to fold it over and put it in your pocket." ![]() |
I mounted mine on the inner fender. On the rubber isolation mounts. It has not been a problem so far. I can get pics if you like. But it looks like there might not be much room there with the ac stuff and that yellow box by the way what is that?
![]() ![]() 400sb-350 crank 400 destroker!!! 377 2.02 dart pro1 alum.heads msd, holley db hooker pro-comps-3in exh. 3 spd. saginaw-3.73posi Flat Bed...want Reg bed...trades? |
i got mine hanged upside side down from the bottom of the glove box. chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. ![]() ![]() 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
Mine is mounted on the inner fender as well. Never had a problem so far.
![]() ![]() 1972 C20 Custom Deluxe: Rebuilt 402 hopped up a bit, th400 with shift kit, Dana 60(wanna have posi), New solid, no cancer, cab. B & M Starshifter floor shifter. ![]() |
'69 Step
Mine's in the same spot as deputyd
It's my truck, and Yes, I CUT the dash, so what?? |
I would worry about cracking the fiberglass as the MSD vibrates...
#8 | |
The "yellow box" is my radiator overflow catch can. lol.
