Old 05-16-2008, 02:13 PM   #1
bellemare_486
bellemare_486's Avatar
3 in the tree to floor shifter?
Finally got a shortbox, '68 c-10. Saginaw 3-speed still in it and the previous owner has attached an indy shifter thru the floor but it doesn't seem to engage reverse and only moves in a strait line back and forth. Does anyone know of an aftermarket shift kit that would give me some kind of an "H" pattern on the floor? I know I should probably get a 4-speed out of a camaro or something but $$$
bellemare_486 is offline   Reply With Quote
Old 05-16-2008, 03:24 PM   #2
Gray Ghost
Gray Ghost's Avatar
Re: 3 in the tree to floor shifter?
Skip the kit you can get at OR's....it's junk. We put one in Bill's son's truck and it was an nightmare of an installation. Get a very good aftermarket shifter. You should be able to find a few out there on the web....google!
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 05-16-2008, 07:10 PM   #3
Mister laugh
I believe Hurst makes a shifter called the Hurst Indy 3spd truck shifter that may be what you want. Can you snap a pic of the linkages you have now it sounds like they may just be worn out or out of adjustment.
Mister laugh is offline   Reply With Quote
Old 05-16-2008, 08:07 PM   #4
tkeduk8r
tkeduk8r's Avatar
I asked this same questiona few weeks ago... if you want the "best" shifter purchase the MasterShifter from Hurst for the conversion.... It si a little spendy however.. about 300 bucks for the shifter and install kit...
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 05-16-2008, 09:50 PM   #5
daveo68
daveo68's Avatar
It'll be more money but worth it in the long run plus installs perfectly.
68 C-10 Custom LWB
307 V8
Lexington,NC
davideowens@lexcominc.net
God Bless America
daveo68 is offline   Reply With Quote
Old 05-17-2008, 03:55 AM   #6
jimfulco
Are you sure it has all the linkage parts present and properly adjusted?
jimfulco is offline   Reply With Quote
Old 05-17-2008, 04:02 AM   #7
67_C-30
I have a radical idea!
67_C-30's Avatar
Sounds to me like it could be hung up. Crawl under ther truck and pull the 2 linkages to get it unstuck. If its doing this its either worn out or out of adjustment.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
