Old 05-17-2008, 01:08 AM   #1
retselgerg
retselgerg's Avatar
motor mount tower location problem on 72
today me and dad were relocating the SBC in his truck to the correct frame mount location,b.c the PO installed the v8 the 6 location, well we got it lined up with the mounts on them but the two bolts to the top of the tower lack about 2 inches touching the frame, it barely moves even with alll the motor weight on them are the towers different for six and eight trucks??
"OLE BLUE" Goodwrench 350, 5speed, Tilt, PS, PB,
"some guys got into cars for money or girls but i got into cars because of the cars" -Jay Leno
retselgerg is offline   Reply With Quote
Old 05-17-2008, 01:55 AM   #2
john
member #16
john's Avatar
Re: motor mount tower location problem on 72
Yes, you will need v/8 towers for the front set of holes.
john is offline   Reply With Quote
Old 05-17-2008, 01:56 AM   #3
retselgerg
retselgerg's Avatar
anyone?? the towers fit to the frame and cross member to the six banger location, but it doesnt seem to fit in the 8 location any thoughts as to why? are they warped?
Old 05-17-2008, 02:26 AM   #4
john
member #16
john's Avatar
TTT posted at same time.
Old 05-17-2008, 04:46 AM   #5
retselgerg
retselgerg's Avatar
anyway someone could post pics of the difference between them for dad to look at.......He is just curious of the difference
thanks..........
Old 05-17-2008, 06:18 AM   #6
Shyguy
Junior Member
Shyguy's Avatar
I don't have any pictures of them, but they are different.
Hopefully some one else will post a few pictures.
Danny
Shyguy is offline   Reply With Quote
Old 05-17-2008, 06:49 AM   #7
tkmad
I'm unclear on V8 and I6 mounts as well. In my '67 with a V8 it looks like there are 3 holes on the frame rails and mine are in the front 2. Is that correct? There seems to be plenty of room behind the engine to the firewall to maount it back the 3 inches or so...
Sorry if I'm hijacking ;-)
tkmad is offline   Reply With Quote
Old 05-17-2008, 07:32 AM   #8
retselgerg
retselgerg's Avatar
the front 2 are correct v8 location,
Old 05-17-2008, 07:38 AM   #9
Select
Friday's Toy
Select's Avatar
All I know is that I had to modify my stock towers to run a TBI motor, changed to card in my prijecy 72 and rework the mounts. I also heard the 72 mounts are the same....but I made some 68's work just fine.....only with a couple hours worth of work. I couldn't get the other motor tower pic to work, but if you want any info, lemme know.
68 C10, SWB Fleetside with a 454, Turbo 400 and 4.11 posi....Exxon/Mobil loves me.
2009 Jeep Rubicon
2011 Powerstroke FX4 (totaled)
71 C10, SWB Fleet with factory tilt
72 LWB C10, 350 700R4 with factory tilt
Select is offline   Reply With Quote
Old 05-17-2008, 07:44 AM   #10
Select
Friday's Toy
Select's Avatar
Double post....sorry. I took the top 1/3 of each tower and cut then off. I then transposed them and welded them up and everything was good to go. I'm to cheap to spend $130 on tubular mounts. Everything is fine under engine torque and looks fairly stock to boot. Only thing for those in the know. I had to mount them under the frame rail instead of on top for stock TBI manifold clearance. Now I have a good 1/2 inch to the manifolds and all this is in the forward holes.
2009 Jeep Rubicon
