Old 05-17-2008, 02:35 AM   #1
jku72
new steel speedometer gear for sm465
I changed the rear gears in my burb from 3.73 to 3.07. I yanked the speedo gear thinking it would be easy to swap it, but this one is steel, and looks nothing like any of the plastic ones I'm used to seeing. Anyone know where I can get a correct speedo gear for an sm465. Its definitely not the same one used on the automatics and muncie 4 speeds.
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
Old 05-17-2008, 04:47 AM   #2
Ace in the hole
Re: new steel speedometer gear for sm465
Not sure if they have the right gear or not but you could try these guys- http://www.speedometershop.com/ratio.html
They could also make you an adapter that would correct the ratio.
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
