Old 05-17-2008, 05:35 AM   #1
Cobblemizer
Smile Broken ground cable
I recently purchased a 1991 k2500 plow truck. The problem i an having is the main braided ground strap on the back of the pass side cylinder head is broken and just hanging there and I cannot see where it was mounted to the fire wall. Any pics of where it mounts would help.
Cobblemizer is offline   Reply With Quote
Old 05-17-2008, 07:09 AM   #2
get me on the road
No Matter What.
get me on the road's Avatar
Re: Broken ground cable
I recently found out I have the same problem on my 89 Silverado, so I'll be watching this thread. I also have a ? that relates, can it be replaced with a ground wire from a parts store, or does it have to be that braided flat cable? Thanks in advance.
Currently own:
89 Chevy Silverado
Previously Owned:Starting with my first vehicle
86 Mercury Cougar /89 Olds 88 /88 Chevy S-10 /84 Pontiac Firebird(I miss it) /91 Chevy S-10
get me on the road is offline   Reply With Quote
Old 05-17-2008, 06:06 PM   #3
66skylarkpost
66skylarkpost's Avatar
that ground goes to a long stud there on the firewall just behind the motor , its either metric or a size 10 , i cant remember which . as for using a differnt wire , as long as you go with a 10-12 gauge copper wire you should be ok
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car
66skylarkpost is offline   Reply With Quote
Old 05-18-2008, 05:17 AM   #4
ChevyTech
The wire does not have to be an exact match but the braided un-insulated wires are very flexible.
Use a wire that is large enough to be able to carry as much current as the original.
Here is a photo of where the braided ground connects to the firewall on a 1993.
Old 05-18-2008, 12:58 PM   #5
Cobblemizer
Thumbs up Re: Broken ground cable
Thank you for the pics and replys. I have a no communication problem with the computer and I hope this fixes it.
