05-17-2008, 05:32 PM | #1 |
turbo enthusiast
4x4 clunking when turning
My '67 burb 4x4 just started making a clunking/popping noise yesterday when I turn right. It doesn't do it everytime, but since I'm about to make an 800 mile drive in it, I don't want to take any chances. It has a '68 3/4 ton closed knuckle dana 44 up front. No power steering. Is there supposed to be a place to lube the knuckles? What do you guys think?
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting " |
05-17-2008, 07:20 PM | #2 | |
Re: 4x4 clunking when turning
I have also experienced bad ball joints popping when turning. Hope this helps lead you to a solution, and I'll subscribe to the thread to keep track of updates, let us know what you find out. Eric |
05-17-2008, 07:54 PM | #3 | |
Have you looked into the lock-out hubs? or wheel bearings? Loose bearings can make the innards of the lock-outs wear excessively. This can make odd noises. |
05-17-2008, 09:00 PM | #4 |
turbo enthusiast
This front axle does not have the lock-out hubs, but I will check on the loose bearings. I just changed the front diff. fluid about 6 months ago.
05-17-2008, 10:25 PM | #5 |
can you add lockouts? Might be an easy fix for now until your trip. Spend $50 on some lockouts and the front axle won't turn any more...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
05-17-2008, 10:28 PM | #6 |
W/O lock-outs, it could be a drive shaft joint or even spider gear noise.
05-18-2008, 12:46 AM | #7 |
turbo enthusiast
For a temporary fix, the front driveshaft has been disconnected since I swapped the axles last year because it is in poor shape and I figured if it was turning all the time it would come apart. Just put a few miles on it driving around town and it didn't make a noise. Where can I buy lockouts for this old Dana 44?
05-18-2008, 01:02 AM | #8 | |
They are 1/4 turn and in good driver shape.... post a pic of your hubs just to be sure that they are the same size...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 05-18-2008 at 01:02 AM. |
05-18-2008, 02:22 AM | #9 |
I have had two "popping" issues with 4x4's, one was the front spring hanger, the rivits were just slightly loose and would pop when you turned, the other issue was my rebuilt power steering box, it will pop, its going back for a new one. Have a buddy look at these things while you work the wheel back and forth.
Good luck with it!!!
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
05-18-2008, 05:49 AM | #10 |
turbo enthusiast
heres a pic of the hub Mike.
05-18-2008, 06:20 AM | #11 |
8 lug with big bearings... mine wont fit... sorry
05-18-2008, 01:53 PM | #12 |
With not having lockout hubs the u-joint have had excessive use,though virtually under no load,still spinning away all those miles.It`s hard to pin point these sounds sometimes.A good ole tear down usually shows something obvious or at least questionable.I`d start with steering and suspension,then the axle/driveshaft.If nothing shows in the axle I`d look at the t-case...in that order.
You can drop your rear shaft and lift the front and maybe track the sound.It helps to have a second person,for sure.I`ve had the steering gear loose,spring bushings shot and the whole rack was shifting,drag link/tie-rods ends bad,ball joints...
05-18-2008, 10:38 PM | #13 |
Arrived on a Pale Horse
I found out once that driving without the front shaft in will destroy your t.c. if it's full time 4x4.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
05-18-2008, 10:52 PM | #14 |
I had a 79 blazer with full time 4WD and did that every summer.... although it couldn't be parked on a slope because something would slip and "bang, bang, bang" away it would roll....
05-19-2008, 02:20 AM | #15 |
turbo enthusiast
Thanks Mike for trying. I don't think I want to keep this front axle so I don't want to invest too much money into it. Just drove almost 400 miles on it today with no problems. Another 400 tomorrow, so I'm keeping my fingers crossed.
05-19-2008, 02:36 PM | #16 | |
None of that applies to a '67 though, "full-time" didn't start until '73 or '74? A '67 should have a Rockwell case. |
05-19-2008, 03:22 PM | #17 | |
I must have just been a coincidence then on my 79. Weak carrier decided to grenade itself. Might have had something to do with the day before. My stepson and I had our trucks back to back in the street playing "tug-of-war" with a tow strap.
05-19-2008, 09:33 PM | #18 | |
05-21-2008, 12:14 AM | #19 |
turbo enthusiast
Thanks guys for all the info. My burb survived the long haul, loaded, from sacramento to phoenix with no problems. Hasn't even made that clunking noise anymore. Thanks again!
