belt squeel
I have a squeeling alternator belt when I romp on the engine. I am very tight on the adjustment. A friend reccomended a step down pulley. Sounded logical........ordered one from Summit and went to change it out with the stocke pulley on the alternator. The aftermarket pulleys hub replaces the alternator shaft bushing and fan. I called Summit and they said this wiould not work on a street engine since without a fan the alternator would overheat and sieze up
What is a solution and still staying with V belt drive?
69 K-20 cloned to a 67 with front clip and some other stuff. 383 .040 over Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears: ![]() |
Re: belt squeel
you sure it's not your water pump bearings going bad?
Rottenwood Garage 1970...71...72 C1500 aka Orange aka Sideshow Bob 540 BB Straub Roller Cam, AFR Magnums, XP 950, TKO 600 2 Tons of Fun |
Re: belt squeel
Did you replace the belt? Try some belt dressing i think its called from an auto store.
72 Cheyenne Super 80 Silverado Blazer 2wd |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: belt squeel
Might be able to stop the squeal by replacing the belt with a new one. A (very) temporary fix -- and to prove beyond a doubt the belt is squealing -- is to rub a bar of soap against the belt while the engine is idling.
Disclaimer: Avoid the fan, don't wear loose clothing, keep your fingers out of harm's way etc. etc.... Edit: Just saw sameyrasmea72's advice for belt dressing. If you were here, I'd give you a nearly full can of it. It didn't work at all for me, just made a mess. Might have been the brand I bought though...
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 05-17-2008 at 11:44 PM. |
Rolled on Paint Club
![]() Join Date: Jan 2006
Re: belt squeel
What kind of radiator fan are you using? I had the same problem, tried several styles of belts including the notched ones to no avail. I ended up removing the fan and going with an electric one. No more squeal.
Bob
1970 GMC 1500 swb fleetside SB 355ci. Smog heads Summit 1102 cam Performer intake and carb. Finally in about 1 piece in the yard. |
I am a Referee of life.
Re: belt squeel
I would suggest cleaning the pulley groove also.I usually use roll emery cloth and just buff the groove well.Cleaning with a wire brush first if it's really grungy.
Also make sure the belt is the right size.I assume the length is OK since you say it's tight but is the width right?V belts come in several widths and using one of a narrower width than the pulleys are designed for will cause squeal.A V belt should not bottom on the pulley but should run a 1/4 in or so from the bottom of the V. Belt widths are designated as A B C or may be an L# designation.The V belts with reliefs(toothed) inside are usually considered to have better grip and are usually a better quality of rubber. You may know most of what I posted but i thought some pointers and/or reminders might help.One company I worked for spent thousands on seminars to train maint people in the finer points of stuff like this. Getting good grip from a belt without having to tighten the belt excessively will help with bearing and belt life.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 05-18-2008 at 12:07 AM. |
Re: belt squeel
I have used the bar of soap method before it works well to determine which belt on a muti-belt pulley system is screaming @ you.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
Living In The Past
Re: belt squeel
The last time I had one (belt) that wouldn't stop squealing ,it turned out the alt was going bad
Re: belt squeel
I just went thru this same problem.
I bought a new belt & it still squealed. But it ended up being that the alt bracket was hitting the top of the alt (1st & 2nd picture) not allowing me to tighten the belt fully. So I had to move the bracket to the front of the alt( last picture). and it allowed me to tighten the belt fully. no more squeal (click pictures to enlarge) ![]() ![]() ![]() Last edited by AustinScott; 05-18-2008 at 03:32 AM. |
Re: belt squeel
new water pump..... Summit heavy duty high flow, alernator rebuilt and checks out fine, new aluminum crank pulley, nw notched belt that is the correct size
for the most part it only squeels slightly when I hit the throttle hard from an idle of say 700 RPM ifI have the engine up to 1200 or so and hit it it won't squeel kinda annoying and I have cleaned the pulley real well the larger stepdown pulley seemed logical, but we need fans on these things
![]() Join Date: Jul 2004
Re: belt squeel
I don't know if the K20 has the same water pump pulley as a C20, but assuming it does, The C20 has a smaller WP pulley than the 1/2 tons. It likely should not squeel, but ours squeels pretty good when wound out. We are going to replace it with one from a 1/2 ton, they are about 7 inches, same as crank pulley, that should slow the fan down enough and give it more surface diameter to grip, that should stop the squeel.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 05-18-2008 at 05:41 AM. |
67-72 Addict!
Re: belt squeel
I got the same problem right before trans down shifts when I romp on it it will squeel real quick and loud!. I was thinking about a deep groove pulley.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
#13 |
Re: belt squeel
googled the problem and belt/pulley alignment seems to pop up.
Hmmmmmmmmmmmmmm????? something else to check I guess. ![]()
#14 |
Re: belt squeel
V belt issues~~~~~~~~~~~~when you think that it's all sorts of things like belt being wrong size, wrong pulley, warn or bad bearings, etc.~~~consider this~~~~~~The pulley cam actually get warn so that the "V" looses the flat nature of the sides of the V and instaed of having good belt to metal contact---you loose some of this frictional contact. Tightening the belt doesn't solve the problem. Using a small straight edge, carefully check to see if sides of the V are warn to start looking like alook like a "U". Replacing the pulleys and using a new belt of the correct size will solve the problem for years to come.
#15 |
![]() Join Date: Dec 2006
Re: belt squeel
You can easily determine if it's the alt.belt slipping by reving the motor with everything off,and then doing it again with the headlights on high-beam,fan,radio(not AC),and if it squeals worse,then it's the Alt.belt. A new belt of the right size on clean pulleys won't squeal if tightened properly.If you still hear something,I'd agree with the guys above about a bearing or something.
Incidentally,about a year ago I bought a lifetime warranteed """""""Rebuilt!"""""""" Alternater from.........................Autozone! and guess what? It rumbled and screeched and I thought My engine was in big trouble,because how could a rebuilt unit be bad? Well it was a total POS so yours might be too.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. Last edited by WorkinLonghorn; 05-19-2008 at 01:23 AM. |
#16 |
![]() Join Date: Nov 2007
Re: belt squeel
This is interesting because I had a squeal in my old motor which I thought was all sorts of crap. I put in my crate motor with new everything except power steering pump. I thought that was causing my squealing. It is similar as described if I am idling and step on it real hard it will squeal. I dont notice while I drive on the street. Is this something to worry about ? The power steering works fine, I think. It doesnt leak at least. The alternator is new, belts new.
72 C20 Longbed 05 1500 Z71 |
#17 | |
Re: belt squeel
#18 |
Re: belt squeel
I know this is an old thread, but I too am having the issue. New belts, new parts and belt dressing (what a mess) and still sqealing on initial startup, or when romping on it. The only thing left is the wider belt as PanelDeland suggests!
#19 |
Re: belt squeel
Having been through this{we all have}recently pulley alighnment is VERY crucial.Had what I thought was a alt belt squeal turned out to be a ps pulley just barely out of alignment,I mean just barely.I had no idea what a small tweak could sound like.
#20 |
![]() Join Date: Feb 2012
Re: belt squeel
how long has this problem been going on? I ran into a similar problem with belt squeel. I had the same size crank pulley but my water pump pulley had two different sizes on it. I took the power str belt off from around the water pump and squeel stopped.
#21 |
Re: belt squeel
Put a Z/28 deep groove pulley on.
