Old 05-18-2008, 04:27 AM   #1
tcb-1
Nothing to see here.....
tcb-1's Avatar
Painting template for hubcaps???
in particular these..... I have some nice (unbent) caps and wondered if anyone has ever whipped up some type of painting template.
wonder how GM was able to mass produce?
here's the examples........
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 05-18-2008, 02:14 PM   #2
Luvlegs
Luvlegs's Avatar
Re: Painting template for hubcaps???
I'd just paint the center blue and put 'em on my truck! I like 'em
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 05-18-2008, 03:01 PM   #3
GRIMSS
GRIMSS's Avatar
Maybe you could sacrifice a bad cap and cut it up to make some sort of overlay type template. It would probably be just as easy to mask it with tape for just 4 of them.
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 05-18-2008, 03:20 PM   #4
LONGHAIR
You might be able to get a local sign shop make you an mask. If you can find a place with a "plotter" they could make you one for the black areas. This would require you to paint the caps black first. Apply the mask and shoot the white second. Peel the mask and you have it.
Cost wise, this is probably not feasable for just one set. The set-up fee would kill it, but once you have that, the individual pieces should not be that expensive.
LONGHAIR is offline   Reply With Quote
Old 05-18-2008, 04:50 PM   #5
tcb-1
tcb-1's Avatar
wonder if some sort of screenprinting place could fill the black areas with........ screenprint?
Doug
Old 05-18-2008, 05:37 PM   #6
LONGHAIR
Probably not, the contour would be an issue. I have only seen screen printing done on flat or cylindrical odjects.
Even if you could, you are still looking at a set-up fee.
Maybe the sign shop could go the other way? Instead of a painting mask, they could make them black. Then you would apply them to a white cap and just leave them on?
Old 05-24-2008, 06:57 AM   #7
roger0080
I was always thinking that I would try making a very very light fiberglass mat over a hubcap as a mold, cut out the pattern from that. Then lay it over the new one a spray it.
They must have done it similarly at the factory as you can see that the color borders are not always "crisp". They may have a feathered look on the edge of the black and white. Which kind of implies some kind of template laid on it for painting.
72 Chev C-10 90% restored (former AZ truck) ...
71 Chev K-20 Cheyenne my vacation crusier...
72 Chev C-10 Now retired and striped after many faithful miles...
72 GMC 1500 Retired to the junk yard after bought new in '71...
roger0080 is offline   Reply With Quote
Old 05-24-2008, 12:58 PM   #8
I`m sure GM had a die-type overlay.I just mask,cut,and shoot.
