Holley 4160 600cfm question
Does anyone know where I can find a good diagram (exploded view) of a Holley4160? Does anyone here have the 600cfm version of teh 4160? If so, where do you have your PCV hose connected? There is a flare on the passenger side, rear of the carb that I think it should go on. I'm not sure and would like some advice.
Thanks in advance.
Scott Shelbourne |
Here's a fairly large pic http://www.holley.com/HiOctn/TechSer...o/4150-60.html
The fitting on the righthand side is usually connected to the pcv (since most chevy v8 pcv's are located on the rear of the pass side valve cover) Then use the vacuum port in #8 intake runner for your brake booster and other vacuum needs. |
Thanks for the link and the info!
Scott Shelbourne |
