Old 05-18-2008, 02:05 PM   #1
1bad chevy
1bad chevy's Avatar
ok suspension guy's ?
i have a 3/4 ton 1972 chevy and i want to put a 1/2 ton suspension out of a 1975 beau jame's edition it has 3.73 posi and is five lug the rear is no problem but as for the front this should bolt right in as in a-frames,and the complete cross member.if not what do i do. but i/m sure that if i unbolt it all as one peice off the frame it should bolt into my 72 i hope
1972 c-20 chevy 500 caddy/4.10posi / 1972 3/4 ton gmc 350 4x4/4.10posi front&rear
1bad chevy is offline   Reply With Quote
Old 05-18-2008, 03:14 PM   #2
LONGHAIR
Re: ok suspension guy's ?
It will all bolt in as one piece. The only issue is the rear-most bolts. They are slightly off. You just have to drill those two holes and you are good to go.
The biggest head-ache of this is supporting the engine while doing the swap.
It would be far easier with the engine out, but I wouldn't go to the trouble to pull it, unless you intend to anyway.
LONGHAIR is offline   Reply With Quote
Old 05-19-2008, 11:36 AM   #3
1bad chevy
1bad chevy's Avatar
thank's i thought it would and yes the motor will be out for it
