05-18-2008, 03:00 PM | #1 |
How hard would it be to switch a 71 body to a newer frame and motor?
Is it possible to take a 71 blazer that had a 350 engine in it, and put it on an 84 body with a 6.2 diesel motor? The 6.2 is a 24 volt military blazer with low miles. Or would the 6.2 fit the 71 trans? What would I have to do to make that work because i want the style of the 71 with the diesel motor. Whats the best way of doing this? Any recommendations? Thanks. -Mike
"Who needs rocker boxes..." |
05-18-2008, 04:48 PM | #2 |
SKINNY TIRES RULE!
Re: How hard would it be to switch a 71 body to a newer frame and motor?
Anything is possible, but that's gonna be a lot of work. The wheel base and width are both different. None of the body mounts will align either. It would be easier to put the 6.2 into the 71. I think there is someone on the board who has done a similar swap.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
05-18-2008, 05:31 PM | #3 |
I Actually Helped A Buddy Put A 93 1/2 Ton Ifs Frame Out Of A Silverado In A Mid Fifties Pick Up
And Let Me Tell You That Was A Chore To Make It Look Proper And Work Proper But He Was Wanting The Suspension And Motor Cause The Old Truck Ran And Road Bad I Think Bouncy Is Right It Would Be Way Easier To Swap Motor To Your Frame The 24 Volt Thing Shouldnt Be That Big Of Deal Just Add Another Batt In Series And Run The Motor With That And All Of The Truck Stuff Leave 12 V Or Convert It Over To 12v But Then You Would Lose Some Of Your Cool Military Stuff IE:water Proof Ignition Parts Last edited by DANTES JIMMY; 05-18-2008 at 08:14 PM. |
05-19-2008, 06:16 AM | #4 |
So would the 6.2 diesel fit the 71 trans?
05-19-2008, 12:46 PM | #5 |
This might help you some:
http://www.race-track.com/news.asp?TOPIC_ID=532 Swapping in the diesel by itself will be tons easier. You should consider doing a 12 volt conversion too IMO. What gears are do you currently have in the blazer? Tires size? Both will determine engine RPM on the highway and a diesel doesn't tach out as happily as a gasser motor. If I were you, I'd find an online gear chart, determine the 6.2 diesel's operating range and do the math before going any further. |
05-19-2008, 11:10 PM | #6 | |
05-19-2008, 11:58 PM | #7 | |
If your currently running 3.08's, you'd be all set. (and not towing) |
