Gas Gauge Question
I have a new cluster and when I plugged the gas gauge wire in it registered off the charts when it was empty. When I filled it up it now points near the 5-6 o"clock range. How do I adjust this?
1969 GMC 3/4 Ton 4x4 2" Lift, A/C, PS, PB 383 Stroker, 700R4, 205, 4.10 GM Medium Bronze (Copper Poly) no new nick name yet. She is to pretty to be the Beater. http://67-72chevytrucks.com/vboard/s...d.php?t=241855 |
Moderator
![]() Join Date: May 2007
Re: Gas Gauge Question
It sounds like the float needs to be adjusted on your sending unit
#3 | |||
Union Electrician
did you go from idiot lights to full gauges? if you did, you need change the wiring harness a little. Look in the truck faq's for the wiring instructions.
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
