Old 05-18-2008, 10:41 PM   #1
mahanian
C10 addict
mahanian's Avatar
Fuel pump to carb fuel Line for 327??
I started to replace the fuel pump in my truck the other day and was removing the fuel line flare fitting at the carb and the fitting broke perfectly in half. The fuel line was in bad shape anyways from the PO so I'm going to replace it. Anyone know where I can find this fuel line for cheap? Is it the same as the 350? I'm doing a LS1 motor swap soon (already have the donor engine/tranny) so I don't want to sink a bunch of money into this engine, just want to get it running so I can drive it for a few weeks. The fuel line feeds into the front side of the carb. Anyone have one laying around?
Jared
67 C10 CST Short Fleet Big Window
65 C10 Custom Short Fleet Big Window
67 Camaro RS
mahanian is offline   Reply With Quote
Old 05-18-2008, 11:49 PM   #2
BarryB
BarryB's Avatar
Re: Fuel pump to carb fuel Line for 327??
Goe get a piece of 3/8 brake line and bent it up and around up to the carb then use rubber gasline to the carb. Use the other end of the brake line into the carb. Do you kinda get the picture??? I have done this numerous times. Cheap and easy fix.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 05-19-2008, 12:07 AM   #3
mahanian
C10 addict
mahanian's Avatar
I think I follow, but shouldn't it be all hard line on the pressure side of the fuel pump or does it not matter?
Jared
67 Camaro RS
Old 05-19-2008, 12:30 AM   #4
Wrenchbender Ret
Mahans method is ok. You can buy them made up at LMC but they are a little high.
Wrenchbender Ret is offline   Reply With Quote
Old 05-19-2008, 01:09 AM   #5
mahanian
C10 addict
mahanian's Avatar
I was hoping to find one for much cheaper than LMC sells it.
Jared
67 Camaro RS
Old 05-19-2008, 02:23 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If you have any junk yards with old stuff, you may get lucky.
A tubing bender is pretty cheap, and nice to have on hand, then a long section of 3/8 brake line from napa (measure your old one) and then try to bend it to the same shape. (buy 2 pieces of line, you can return the one if you get it right the first time) It's actually pretty easy.
Old 05-19-2008, 02:27 AM   #7
mahanian
C10 addict
mahanian's Avatar
Thanks for the info, if I can't find one on here or locally in the next few days I'll just bend one up
Jared
67 Camaro RS
Old 05-19-2008, 05:46 AM   #8
tim21391
tim21391's Avatar
i replaced a fuel pump on my truck...i went and bought the brake line like that one guy said..then autozone and a handheld bender thing that works great to bend that line...its a tool you borrow from them....i know all the guys from autozone so they let me use it for free..you might have to make a refundable deposit on it...
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 05-19-2008, 07:56 AM   #9
clay68c10
clay68c10's Avatar
Yup, bend it yourself. It's way easier than it looks.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 05-28-2008, 03:54 AM   #10
tim21391
tim21391's Avatar
well i did and it turned out the same as my other one....havent had problems since
