05-19-2008, 01:35 AM | #1 |
How do you get the front cab mount bolts loose?
Got the nut off them but the bolt appears ro be welded on.
Thanks in advance
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together) |
05-19-2008, 01:39 AM | #2 |
Re: How do you get the front cab mount bolts loose?
It is welded on! leave it there and lift with it on, or if you need it off,grind spot weld off
05-19-2008, 01:40 AM | #3 |
Moderator
Good luck! I had the same thing happen when I changed mine. It is probably permanently rusted inside the sleeve. I had to cut it off with an angle grinder.
05-19-2008, 01:43 AM | #4 |
Moderator
I was assuming you wanted to change the bolt also. If that is not the case, then do what otsenre said.
