Old 05-19-2008, 03:28 AM   #1
Sinister
Between Trucks...
Sinister's Avatar
Got my dash cut and my stereo installed
Thanks to help from the board I was able to cut my dash and get my stereo installed. Sounds great! I was thinking I might need an amp, but it's so loud I can't even hear my motor anymore. Doesn't look too bad. There are slight dimples on the sides from where there were indentations for the stock knobs, but they can always be bondoed away. PO cut the doors for two sets of speakers and I wasn't able to put the grills on my 6x9's do to clearance issues. I still need to rattle can the speaker wires at the door jamb. Pretty straight foward job and I'm glad how it turned out.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 05-19-2008, 03:43 AM   #2
tcb-1
Nothing to see here.....
tcb-1's Avatar
Re: Got my dash cut and my stereo installed
ya did good Sin! Looks nice.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 05-19-2008, 04:47 AM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Everybodys gotta have tunes...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 05-19-2008, 05:18 AM   #4
Riveted1
Tasty Cakes!
Riveted1's Avatar
Looks good! Glad you got it worked out. You could always build some grilles that cover both speakers if you wanted to.
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 05-19-2008, 05:32 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
And that's how it's done!
Old 05-19-2008, 05:37 AM   #6
Sammy
Not a bad job. At least you used a cutoff wheel & high speed not a pair of dikes & a hack saw blade. I have seen some disasters but that looks decent. Congrats.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 05-19-2008, 05:16 PM   #7
Sinister
Between Trucks...
Sinister's Avatar
I think I'm gonna try trimming down the grills for the 6x9's to see if they'll fit. it's just about 3/8" off.
Beat it to fit,
Old 05-19-2008, 08:07 PM   #8
Sinister
Between Trucks...
Sinister's Avatar
Well I trimmed the grills for the 6x9's and got them mounted. Little problem though, the grills are a plastic frame that goes around the speakers and then a metal mesh that pops into the frame. When I close my doors the mesh part flys out of the frame. I tried bending them to get a little tension but no luck. Anybody ever have this problem? Maybe I should epoxy them in?
Beat it to fit,
Old 05-19-2008, 08:21 PM   #9
leddzepp
Moderator
leddzepp's Avatar
A little bit of black RTV will hold them in place
leddzepp is offline   Reply With Quote
Old 05-19-2008, 08:28 PM   #10
Sinister
Between Trucks...
Sinister's Avatar
Thanks, I'll give that a try.
Beat it to fit,
Old 05-19-2008, 08:34 PM   #11
Longhorn Man
DON'T use super glue... it'll discolor everything plastic and look like crap.
Old 05-19-2008, 08:46 PM   #12
Sinister
Between Trucks...
Sinister's Avatar
The groove the metal part fits into is pretty shallow so I don't think adhesive of any kind is gonna work. But there are some plastic tabs on the frame, and I think I can use some hollow wall anchors and small bolts through the metal screen.
Beat it to fit,
Old 05-19-2008, 08:57 PM   #13
leddzepp
Moderator
leddzepp's Avatar
You can also try loosening the mounting screws SLIGHTLY...not enought to make the speaker move around, but enough to take some tension off. Sometimes they are mounted too tightly, and they will warp slightly, causing the grill mesh to not stay in firmly.
Old 05-19-2008, 10:08 PM   #14
Zonaman
Zonaman's Avatar
Doesn't #11 say "Thou shalt not cut thy dash"?
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus!
Zonaman is offline   Reply With Quote
Old 05-19-2008, 10:17 PM   #15
Sinister
Between Trucks...
Sinister's Avatar
LOL, around here it seems like it. I kept the cut pieces just in case though.
I just didn't like the offerings for aftermarket stock style stereos, pretty expensive for what you get and they're kinda ugly IMHO. I only got $200 in this, and that included the new dremel.
Beat it to fit,
Old 05-19-2008, 10:18 PM   #16
GKsport67
GKsport67's Avatar
Looks nice kiddo! ...OK NOW IT'S TIME TO HEAD BOB
GKsport67 is offline   Reply With Quote
Old 05-19-2008, 11:00 PM   #17
gn4u2c2
nice. I like the holes in the doors also.
gn4u2c2 is offline   Reply With Quote
Old 05-19-2008, 11:36 PM   #18
Jtrux
I'm a poor spectator
Jtrux's Avatar
I'm gonna be putting an AC dash in my blazer and before I weld it in i'm gonna do the same. I figure if i'm replacing the dash all together I might as well make it exactly how I want it and give it some tunes.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 05-20-2008, 03:23 AM   #19
Longhorn Man
yep, I just cut the burb's dash today too... got a kick ass stereo in there now instead of the cheesey old POS 8 track player.
Old 05-20-2008, 03:54 AM   #20
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Lookin' good Sin!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
