05-19-2008, 03:54 AM | #1 |
steering column install
Ok I'm sure this has been covered many times, but I can't find anything. I need pics of a steering column installed in a 67 - 72 non auto truck. Preferably under dash. I got the mount in the firewall, but what holds the column to the dash, what keeps it from flopping around?
Thanks Erik
1969 4x4 Nothing beats a good rock drill and some dynamite |
05-19-2008, 04:27 AM | #2 |
The Older Generation
Re: steering column install
There is a bracket that looks like part #2 in the picture in this thread. This picture is of a bigger truck and the bracket is a little different shape but at least you can get an idea of what you are looking for. http://67-72chevytrucks.com/vboard/s...column+bracket I just took one of these brackets off of a truck yesterday. It's too late to do it tonight but I can take a picture of it and post it in the morning if you want me to. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 05-19-2008 at 04:31 AM. |
05-19-2008, 04:30 AM | #3 |
'71 chevy s.bed/s.side
The column tube has a square cut hole that fits into a tab on the brake/clutch pedal bracket. Then the "half clamp" in the pic here bolts to the brake/clutch pedal bracket. This holds the column in place. Then the large plate bolts to the brake/clutch pedal bracket and then the smaller piece attaches to the dash and acts as a trim piece. I do not have a pic of it installed, but if you need one after reading this, PM me and I'll get a pic tomorrow. If you do not have these pieces, I do have a some that have been blasted, primed & painted with the correct bolts.
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! |
05-19-2008, 04:34 AM | #4 |
Thanks Botietruck. Yours look a lot nicer than mine..... LockDoc
05-19-2008, 06:52 AM | #5 |
Thanks you guys. Botietruck That half clamp bracket is the one I was looking for. I should have it laying around on the bench somewhere. I remember seeing it, but I took the truck apart 1 1/2 years ago and forge somethings lately. I am using the ebrake handle from a 67 so that should replace the big plate looking bracket. Thanks LockDoc for the link to that picture I saved that to my files for later when I am sure I will need it again.
